Pumpkin interchangability
Old Jun 16, 2010 | 08:01 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
the pumpkin carriers/housings are all the same - the differentials and ring and pinions are what differs between manuals and auto's.
an auto ring and pinion can only mate to an an auto differential (either stock or aftermarket) . The only aftermarket diffs I am aware of specifically for an auto are Quaife and Cusco FWIW.
A ring and pinion for a manual (3.9, 4.08, etc) can only mate to a differential for a manual transmission car (either stock (open or VLSD) or aftermarket
Old Jun 16, 2010 | 08:07 AM
J. Dub's Avatar
J. Dub
I'm curious to know if like in the 4x4 world you have diffs that are for certain R&P's?
For example does quaife make a 3.3 diff, 3.9 diff, & a 4.08 diff? All the same diffs but the quaife 3.3 diff wouldn't mate to the 4.08 R&P? Do I have that logic down?
If so this is making sense in my head now.
Old Jun 16, 2010 | 08:13 AM
Z1 Performance
Former Sponsor
you have 2 types of differentials - ones for an auto, and one for manuals, they are not ring and pinion specific (well, I guess you could consider the auto one specific, as I am not aware of any other ratio for auto's except the stock 3.3).
Old Jun 16, 2010 | 08:23 AM
J. Dub's Avatar
J. Dub
I see.
So w/ the above mentioned, if I wanted to run 4.08 ring and pinion final drive for my 5AT transmission I'd need to get a manual transmisison FD housing aka pumpkin, a manual transmission quaife LSD, then the 4.08 gears would work w/ my 5AT?
Old Jun 16, 2010 | 08:25 AM
Z1 Performance
Former Sponsor
no - please reread what I've posted, and what I've pm'd you
this is also covered in a few threads as well, as well as listed on our website
Old Jun 16, 2010 | 08:41 AM
J. Dub's Avatar
J. Dub
I am an idiot. So, we may have to resort to pictures of stick figures.
Seems I will need to find a manual trans pumpkin/ FD housing before I can proceed to order 4.08 gears. Thanks so much for the help!
Old Jun 16, 2010 | 08:50 AM
Z1 Performance
Former Sponsor
no, that is not the case at all - if you need a manual pumpkin, I would have told you you need a manual pumpkin through this thread and PM's
from post #21
"the pumpkin carriers/housings are all the same - the differentials and ring and pinions are what differs between manuals and auto's."
AKA - you can use your auto pumpkin, you will need a new diff and the ring and pinion and the associated install parts
Old Jun 16, 2010 | 08:57 AM
J. Dub's Avatar
J. Dub
from post #21
I just got hard... In the pants. This is great news, thank you Z1. When I order from your site do I order the quaife LSD for an automatic or for a manual?
Old Jun 23, 2010 | 05:06 PM
Vader007's Avatar
Vader007
J.Dub
If you want to run the 4.08 gears, you have to get the Quaife for the manual.
But because you are replacing both the gears and the LSD unit you can install them
in your 5AT pumpkin.
The only difference between the auto and manual diff is the thickness of the ring gear/hense the thickness of the LSD mounting flange.
I think this should sum it up for you.
1973camarolt
Drivetrain
Oct 11, 2015 01:26 PM
Fixxxercask
Drivetrain
Sep 28, 2015 11:15 AM
issyz
Sep 12, 2015 04:18 PM
stereoneeds
Dec 13, 2005 07:16 PM
NismoGCoupe
Jun 14, 2005 02:21 PM
