Diff question.
Old Aug 28, 2009 | 01:33 PM
03brembo's Avatar
03brembo
Default Diff question.
2003 Track w/82k mi
swapped out to 4.08 final, was told to change diff. fluid after 300mi.
waited about 1250mi before finally getting to diff fluid change.
diff started making howling/grinding noise after about 1000 mi.
dont ask me why i put it off so long, *** me right...
money was tight and i would tell myself tomorrow tomorrow tomorrow...
diff is 90% blown and need a new one.
main concern is if the 4.08s are ruined or its another internal making that sound?
any similar situations?
thoughts, i dont care about flamin i know i fuked it up, one way to learn i guess.
thanks
Old Aug 28, 2009 | 01:44 PM
GeauxLadyZ's Avatar
GeauxLadyZ
I have heard many who do this upgrade have abnormal sounds from the diff...like a howling.
Did you get the full #2 kit from Z1 or similar, so that everything thats recommended be changed out with the new ring/pinion are changed out?
Old Aug 28, 2009 | 01:50 PM
03brembo's Avatar
03brembo
ya i got all the shims and stuff, the full kit. i was hoping that the gears were salvageable with nothing wrong, and not both diff and gears..
Old Aug 28, 2009 | 02:08 PM
03brembo's Avatar
03brembo
does anyone know if the postponement of the fluid change is severe enough to cause noticeable damage or put stress on the other internals enough to damage??
Old Aug 28, 2009 | 05:27 PM
turbotoy's Avatar
turbotoy
Samething happen to me. I installed 3.9 gears. Replaced all bearings and after 750 miles hoooooowlllllllll. I put the 3.5's back in with the same bearings and shims and get a perfect gear tooth pattern. I chalk it up to an installation error on my part. Maybe not getting the pinion depth correct. But everyone I talked to said that when they install their gears they rarely change the pinion depth. Sometimes you just get a bad (soft) set of gears.
Old Aug 28, 2009 | 09:14 PM
03brembo's Avatar
03brembo
do you think it has anything to do with the post i posted right above yours??
Old Aug 29, 2009 | 02:54 PM
03brembo's Avatar
03brembo
anybody?
preparing for the worst
Old Aug 29, 2009 | 04:14 PM
turbotoy's Avatar
turbotoy
honestly no
I installed a dif at the same time. I did my figure eights and then changed the fluid. I then drove 750 miles (was supposed to change at 500). I don't think that the extra 250 miles destroyed the R&P.
I could be wrong but I am almost certain it was a bad set of gears or setup.
Old Aug 29, 2009 | 09:46 PM
03brembo's Avatar
03brembo
hmm ill have to look into that. i had a local Z shop do it so i assumed they knew what they were doin.
ya cause i waited almost 1000mi after i was supposed to change it..
they said the fluid was about half gone and was silver from all the metal shavings when they changed it at 1250mi after install...
Old Aug 29, 2009 | 10:44 PM
turbotoy's Avatar
turbotoy
If the fluid was half gone then something mechanical is wrong or they didn't fill it all the way. The silver fluid would be somewhat normal for a R&P brake in.
If it got hot enough to burn that much fluid then it would be obvious. The metal inside would tell the tell.
Old Aug 30, 2009 | 12:07 AM
03brembo's Avatar
03brembo
im just hopin that i can get by just replacing the diff and reusing the 4.08s
they are gonna open it up on monday and let me know
Old Aug 30, 2009 | 12:51 PM
terrasmak's Avatar
They fcuked up, you could have gone 10k miles and been fine.
Old Aug 30, 2009 | 02:06 PM
03brembo's Avatar
03brembo
what do you think i should tell them. ive been taking it there for a few years now for work on my car. do you think there is a warranty on the 4.08s?
Old Aug 31, 2009 | 01:42 PM
GeauxLadyZ's Avatar
GeauxLadyZ
No, but you should def get them to try and fix the problem.
I know for a fact that another guy on here had the same problem and install was done by a VERY reputable shop here on the forums, one of the best for the Z imo.
As far as i know, as of yet they couldnt fix the noise problem. Do a search and you will find the thread.
Old Aug 31, 2009 | 03:57 PM
turbotoy's Avatar
turbotoy
If you had nothing to due with the install. They should at least warranty their work this should be separate from any manufacture type warranty. If you have been going there for awhile then they will probably eat the cost to satisfy a loyal costumer. But you are going to have to make a big deal. I don't mean a temper tantrum but a tactful big deal!!!
Glenn350zHR
Drivetrain
Nov 30, 2015 08:21 AM
1973camarolt
Drivetrain
Oct 11, 2015 01:26 PM
Bodyboarder81
Sep 21, 2015 06:23 AM
_koubie_
Sep 20, 2015 06:34 PM
3vilbunny
Sep 13, 2015 12:31 PM
