Cusco RS installed got a hard noise when I turn help please!!!
Old Aug 12, 2009 | 12:51 PM
cedoulinou's Avatar
cedoulinou
Default Cusco RS installed got a hard noise when I turn help please!!!
Hi guys,
I just installed a cusco RS diff on my car and when I turn at low speed there is hard sounds coming from the differential like just one toc! or toc! toc! toc! at the same time the car gives big hits... I need your help to find the problem. Maybe the installers did not put the good differential fluid??? If it is the problem what fluid should be the best to put in the diff???
Maybe the LSD is broken, I don't know but I hate the feeling for the moment.
It do this only when I turn the steering to 60 degrees or more. It doesn't do it at very low speed or when I hold the clutch while turning.
help me please
Old Aug 12, 2009 | 02:27 PM
BloMyS14's Avatar
BloMyS14
Welcome to a clutch-type differential.
Old Aug 12, 2009 | 09:46 PM
cedoulinou's Avatar
cedoulinou
Are you sure that it is normal to feel a really hard knock when I turn at low speed or sometimes it makes the same sound but many times in a row (toc toc toc toc toc--very fast). If it is normal what is your trick to drive your car without it looks like a garbage???
Old Aug 13, 2009 | 02:55 AM
mw9's Avatar
mw9
+1, I have the Nismo and its pretty loud. Mine did quiet down alittle after the first break in period. I run amsoil and mine is pretty quiet now, after a few thousand miles.
Old Aug 25, 2009 | 09:13 AM
clubhopper's Avatar
clubhopper
what configuration did you set your cusco type-rs lsd to?
1.5way, 2way? how much locking %? i think the amount of harshness depends on what your settings are. gentler settings usually are quieter imo
Old Aug 25, 2009 | 11:12 AM
terrasmak's Avatar
Sounds like someone wanted a COOL part and really had no clue about it.
Old Aug 25, 2009 | 11:26 AM
bboypuertoroc's Avatar
bboypuertoroc
This.
Old Aug 26, 2009 | 07:53 AM
cedoulinou's Avatar
cedoulinou
1.5 way 60%
Old Aug 26, 2009 | 08:11 AM
Zazz93's Avatar
Zazz93
Sorry brah, that's the way clutch type LSDs work. Sucks the seller didn't warn you. I always thought the product details should reference the noise.
Old Aug 26, 2009 | 08:31 AM
Lee R's Avatar
Lee R
I think it sounds rad!
Old Aug 31, 2009 | 09:50 AM
clubhopper's Avatar
clubhopper
What kind of fluid is in there right now? Some ppl run Amsoil, Motul, or Redline which in their opinion seems to quiet down the diff siginificantly.
I should be dropping my Cusco RS diff in next week (just configured it last night). It is set as a 1.5way 100% lock. I'll be running Motul PA90 (thats the one with the friction modifier). I'll let you know if i get the type of noises you get.
Please keep in mind that clutch based LSD's give off noise but the amount of noise in some cases can be altered with fluid choice, LSD choice and break-in procedure. (It was broken in right?)
On a side note. I installed a ATS Carbon 2-way LSD into my buddy's G35 last night. During break in (figure 8's) there was very little noise, and during driving it was completely silent. You may want to consider this diff if noises bother you that much.
Personally, i wouldn't worry about noise. Call it a badge of honor!
Old Aug 31, 2009 | 11:10 AM
marra23's Avatar
marra23
Redline didn't last long with my Nismo.
Old Aug 31, 2009 | 12:38 PM
turbotoy's Avatar
turbotoy
I have never heard a peep out of my solid axle clutch type LSD's. I think this may be unique to an independent rear setup.
Old Aug 31, 2009 | 04:23 PM
Zazz93's Avatar
Zazz93
I have heard some that are more quiet than others, but most have continued to make a slight noise after break in, and depending on the maker even after break in they continue to make a noticiable amount of noise. The loudest I've heard unfortunately was the Cusco. This was on a STI, and months after the break in it still made a very loud clunking noise when it was engaged. I'm not sure if they are setting sensitive as for as the noise goes but I would suggest trying a softer setting. Due to the design nature of the smaller swell may yield a lower noise.
Old Sep 1, 2009 | 09:58 AM
Wu-Watt's Avatar
Wu-Watt
I have the KAAZ lsd.. Makes the same noise.. One time I pulled in to get gas and it was popping like crazy.. I got a look or two.. Meh..
Obadabot
Jun 18, 2023 11:31 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
samansharif
Sep 25, 2015 12:31 PM
