Serious MAF Issues
Old Sep 19, 2009 | 06:17 AM
DJADL's Avatar
DJADL
Default Serious MAF Issues
I bought my car used a few months ago and it came with a CEL on. First it was on for the TPs but I fixed that. Now its throwing a MAF sensor code. I have a 5/16 thermoiso plenum spacer and a JWT pop charger. I even replaced the MAF a few days ago and it still throws the code. I know my filter is not over oiled because I literally blew all the oil I could out of it. The light will stay off for 25 or so miles and then BAM back on, randomly. I don't know what I could do next or how to fix it but my inspection is due and im pretty sure they wont pass me when im throwing a CEL.
ANY IDEAS would be much appreciated
Eddie
Old Sep 19, 2009 | 09:33 AM
tylerxfire's Avatar
tylerxfire
start at going to advanced auto or something and seeing what the code saying? that will tell u what is wrong
Old Sep 19, 2009 | 09:36 AM
03threefiftyz's Avatar
03threefiftyz
Did you replace the maf housing or sensor? If you are throwing a multiple/random misfire it is usually a leak after the maf housing or that the sensor needs to be cleaned. You need to figure out what the code is first.
Old Sep 19, 2009 | 10:42 AM
DJADL's Avatar
DJADL
the sensor was cleaned right before i put it in. I did it very thoroughly. Do you need the exact code number because it kept saying Mass Air Flow Error. I replaced the sensor not the housing
Old Sep 19, 2009 | 10:44 AM
tylerxfire's Avatar
tylerxfire
u need the exact code, u prolly have a leak or somethin
Old Sep 19, 2009 | 10:56 AM
cdoxp800's Avatar
cdoxp800
Agreed. The CEL code would be real helpful.
Old Sep 19, 2009 | 12:35 PM
DJADL's Avatar
DJADL
there were two codes both P1283 but one was set and the other was pending
Old Sep 19, 2009 | 12:55 PM
03threefiftyz
P1283 is a code for lean condition A/F sensor 1 bank 2................are you sure this is related to the maf?
Old Sep 19, 2009 | 12:56 PM
Quamen's Avatar
Quamen
Edited because ^^^ beat me.
Possible causes area:
 Air fuel ratio (A/F) sensor 1 heater
 Fuel pressure
 Fuel injector
 Intake air leaks
My guess is intake air leak given the changes you made.
Old Sep 19, 2009 | 01:07 PM
DJADL's Avatar
DJADL
how should I go about trying to fix it?
Where should I check for the leaks?
And how would I check the A/F sensor?
Old Sep 19, 2009 | 01:18 PM
Quamen's Avatar
Quamen
You can check for volatage across the leads of the O2 sensor.
For an air leak some people use smoke to see if air is getting sucked in somewhere. Some people spray carb spray around the seams and find the leak when the engine idle bumps up.
Old Sep 19, 2009 | 01:43 PM
DJADL's Avatar
DJADL
where is the A/F Sensor?
If it is an air leak how would I fix it?
Would the air leak be in the tube or the spacer for this code?
Old Sep 19, 2009 | 01:54 PM
03threefiftyz
Could be either......I would just go through it, take apart the upper plenum (and intake), and reassemble it. Then clear the codes and keep your fingers crossed .
Old Sep 19, 2009 | 03:17 PM
DJADL's Avatar
DJADL
The car has always made a weird noise when i accelerate, it sounds like metal pieces churning in something, I thought it was always due to the thermoiso just makin weird noises, could it be leaking air or something?
350Z_Al
Oct 29, 2020 07:44 PM
350z82
Oct 1, 2015 06:25 PM
