New Grounding kit......
Old Dec 10, 2009 | 09:50 AM
Ronin82's Avatar
Ronin82
Originally Posted by F34RL355
you realize taco bell is below dog grade meat? dont eat that sheet MOD your diet
.....Ok frenchy!!!!.
Old Dec 10, 2009 | 09:57 AM
blasian's Avatar
blasian
Originally Posted by Z You Later
yes most will consider this a placebo affect with adding the ground kit but you have to realize that the Z out of the factory has terrible ground support. if you go to japan, they actually give an upgraded grounding kit as an option.
i will say that there is NO performance gains from this, as nobody has posted any dyno sheets reporting a gain, BUT it does clear up static noise and DOES make your car run more efficiently..so placebo affect? performance wise yes, but to the small and over-looked things, yes it has made a slight improvement.
I've heard the same exact thing.
Old Dec 11, 2009 | 04:49 AM
Ronin82's Avatar
Ronin82
Problem fixed.....
Took it to JMS in Converse, Tx, explain to the mech/tech the issues, was had an issue with his G35 of the same nature with the voltage losses in the cold weather....
Also handed him New spark plugs, PCV valve, and a new intake filter(even though filter I believed was still clean), all for regular maitenence that was due.
Came back 2hrs later everything was done. Said he increased the idle just a lil bit and swaped out plugs/filter and PCV. Took it on a run for about 30minutes. The idle feels good, vibration in the shifter and steering wheel feels smoother yet a tad more aggressive and clean intake filter seems good.
Temp outside was 45 degrees.
Kept an eye on my voltage gauge and it seems to only give when I power my windows and switch to my HID's but jumps right back to its norm. Needle doesn't slowly decline at stop lights. This was the reason I did the GK, NOT for "extra Power"
as far as a "placebo effect", I can't say cause of the other variables I had done. could have been the plugs,filter, or standing idle speed or all thee above. I do know that the GK is not hurting the engine and I wanna say it feels smoother and more efficient, but there are to many other variables that could be overshadowing this end result.
...now... I feel better
Old Dec 11, 2009 | 09:12 AM
Z You Later's Avatar
Z You Later
well glad to hear that you fixed the problem...now get out there and drive!
Old Dec 11, 2009 | 10:05 AM
screener's Avatar
screener
Congrats, now back to just worrying about rear tires.
Old Dec 12, 2009 | 10:13 AM
dhays's Avatar
dhays
I don't do all my own maintenance and repair. I pick and choose depending on time, money, complexity, and pure laziness. However, I would encourage you do replace your own intake filter. That is about the easiest 30 second job there in on the Z. Since it is so easy and since filters are so cheap, it is something that you can do as part of your regular maintenance.
Dave
416blueZ
Jun 11, 2024 10:56 AM
m_0g
Jun 3, 2021 10:05 AM
hulkout
Tuning
Sep 30, 2015 12:33 PM
OdesiTT
Sep 30, 2015 10:47 AM
cashmoney03
Sep 27, 2015 05:24 PM
