Converting open diff to posi on a 2003 350z questions
Old Jan 29, 2010 | 05:25 PM
NitroViper's Avatar
NitroViper
Question Converting open diff to posi on a 2003 350z questions
I'm sure many of you have done this? What does it consist of? Is it as simple as changing clutch packs? I'm not very educated in this area and hoping its relatively a cheap task. I want to buy a turbo kit for my car and cant have 1 tire spinning all the time. I need to be able to get a good launch off the line.
Guys got an suggestion on the best/cheapest way to do this?
Old Jan 29, 2010 | 05:33 PM
TheFarmer's Avatar
TheFarmer
Cheap task? Not really. You will need to change out your spider gears for a LSD unit. Essentially changing the guts. The cheapest way would be to pick up a used VLSD unit off a non-base 350z.
Old Jan 29, 2010 | 05:49 PM
NitroViper's Avatar
NitroViper
any idea of prices for that kinda stuff? What would I look for on say car-part.com? 350z LSD unit?
Old Jan 29, 2010 | 07:13 PM
hellsoldiers08's Avatar
hellsoldiers08
plan to drop a G on the project.
Old Jan 29, 2010 | 08:41 PM
NitroViper's Avatar
NitroViper
a G doesn't help me find what im looking for.
What do I look for as in parts? maybe I can find someone parting out a car or something on the forum. I look for a LSD rear diff?
Old Jan 29, 2010 | 10:07 PM
drivessidewayz's Avatar
drivessidewayz
First off, define "relatively cheap". There are guys around these forums that have invested over $50k in their cars.
Second, there are *tons* of aftermarket differentials. However since you have the base, you'll need the output shafts from a VLSD model which will run you about $300 new from Nissan. This is in addition to any aftermarket differential you find, including the VLSD models. If you'd like to do it for the lowest price, you can either go with the Quaife differential or the new Nismo imported from Japan. Both will run you about 1.5k after shipping.
Third, if you're not that knowledgeable in this area, you'll want to find someone to install it for you. That will run you about $3-400 if I remember what others have said correctly.
While the cheapest way is most likely to find a used VLSD, I've heard that there's a world of difference between that and the aftermarket diffs (I have a base, I wouldn't know) and that the extra 1k is worth it.
This is just information I've gathered around the forums and I am presenting to you. Note the "I gathered around the forums" part...lol. I hope you're also aware that a new turbo kit is 5k+ not installed.
Side note -> "best" and "cheapest" don't often go together.
Edit: The Quaife does not need the output shafts and to my understanding the Nismo comes with them.
Old Jan 30, 2010 | 07:48 AM
NitroViper's Avatar
NitroViper
Thanks for the help. Just trying to see if its worth it to get a turbo kit with limited money. Looks like its running into to much money. Might have to stick with a cool looking car thats not very fast lol.
Old Jan 30, 2010 | 12:12 PM
AZHR's Avatar
AZHR
first off i'm not trying to be a d!ck here, it's just the internet
going FI with limited money is a no no, turbo kits are not cheap. do not cut coners when going FI. also do not go with the ebay no name kits. if you do cheap out you will be paying for it in repairs. there are people on this board that put in the time and money into building up there motors, and still go pop. FI is fun but it gets very expensive (more than a fan of 20$ bills )
As far as base to LSD, Quaife can drop right in. i know Z1 sells a kit that has everything you need to convert it. then you can get any LSD made for the Z's that come with the VLSD. i did this, since i wanted the a 1.5 diff.
Quaife will be the "cheap" way to go since it drops in. have a pro install it.
Old Feb 2, 2010 | 05:05 PM
Lawn Dart's Avatar
Lawn Dart
Nothing "drops in." Any aftermarket LSD must be properly shimmed. As a minimum, you need a dial gauge with a magnetic base and some gear marking compound. Shims cost about $40 a pair and range from 2.00 to 2.65 mm in 0.05 mm increments.
Old Feb 3, 2010 | 08:55 AM
Asterix's Avatar
Asterix
The Quaife unit is not a "posi" (from the thread title). That may matter to NitroViper.
Asterix
Old Feb 3, 2010 | 01:43 PM
ramirj2's Avatar
ramirj2
Just put a Quaife.Drop, especific for base in with no modifications, mechanical no clutches to change, quiet operation.
Old Feb 11, 2010 | 03:46 AM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Asterix
Posi-traction is a term from the 60s. The Quaife is better than a "posi" in every way.
Old Feb 11, 2010 | 04:18 AM
JasonZ-YA's Avatar
JasonZ-YA
NitroViper:
http://www.z1auto.com/prodmore.asp?m...ne&prodid=2349
Old Feb 11, 2010 | 07:34 AM
tiguy99's Avatar
tiguy99
This is good to know. Are there any aftermarket VLSDs that don't run quiet? I'm interested in either picking up a stock 3.3 VLSD pumpkin or converting my open diff to VLSD but want quiet operation.
I ended up selling a 3.5 VLSD diff last spring bc it was whinning at 60MPH and had to have my 3.3 open diff reinstalled (not fun)
I'd like to avoid going through that experience again
Old Feb 11, 2010 | 07:54 AM
ramirj2's Avatar
ramirj2
VLSD – is oil based limited slip. It depends on the ability of the oil to sustain viscosity and then traction. These have a limited life span and eventually act like an open diff.(also on a track after a while and temp rises acts like and open diff.)
Quayfe – is mechanical LSD not dependant of clutches or oil viscosity. It should last for very long time no special maintenance, no noise.
I decided to pick this one and never look back.
Old Feb 11, 2010 | 07:57 PM
carboneticz's Avatar
carboneticz
ATS also offers LSDs for the z base model which do not require changing the side shafts.
Old Feb 12, 2010 | 09:57 AM
Asterix's Avatar
Asterix
Overall, neither is superior to the other. They act differently in certain situations. Each has advantages and disadvantages.
Asterix
Old Feb 12, 2010 | 10:12 AM
AcidJake75's Avatar
AcidJake75
Living in 350Z
^^^+1 on the disadvantages and advantages of each..
Quaife LSD FTW!
EASY plug and play install (for a BASE)
Old Feb 14, 2010 | 08:35 AM
TinmansZ's Avatar
TinmansZ
I installed a Quaife and 3.9 gears at the same time couldn't be happier.
Glenn350zHR
Drivetrain
Nov 30, 2015 08:21 AM
1973camarolt
Drivetrain
Oct 11, 2015 01:26 PM
NYGiants0186
Sep 8, 2015 10:37 AM
RWDBajan
Sep 8, 2015 06:25 AM
