Check engine soon. Can't go higher than 2k rpm
Old Feb 23, 2010 | 06:59 AM
cpatel529's Avatar
cpatel529
Default Check engine soon. Can't go higher than 2k rpm
I was driving to wok today and all of a sudden on the highway my check engine soon light came on and my rpm started decreasing. I could jee it above 2000. I had to pull off the rod and call a mechanic. Any one had something like this occur. I'm hoping it's not serious.
I have an 07 roadster. The engine is stock except for aftermarket air filters.
Any help would be much appreciated.
Chirag
Old Feb 23, 2010 | 08:17 AM
What did the mechanic say? Was the car towed?
Old Feb 23, 2010 | 08:29 AM
solidfish's Avatar
solidfish
Does the 350z ecu have limp mode? If there is a sensor failure or something seriously wrong, the engine will go into 'limp mode' where you cannot accelerate or drive past a certain speed. Its to prevent damage to the vehicle yet giving enough function to pull off the road.
Old Feb 23, 2010 | 08:33 AM
cpatel529's Avatar
cpatel529
We did a diagnostic on the codes amd it was p1217. It's the fuel air metering. He reset it the check engine soon light went away. Drove a mile and it happened again. Mechanic drove the car and kept resetting the check engine soon light. Noticed that it was overheating. Pulled over and getting it towed to Nissan dealer in San Diego. Coolant levels were fine.
Old Feb 23, 2010 | 09:04 AM
MTB350z's Avatar
MTB350z
Happend to my girlfriends 04 tiburon. Ended up needing a new fuel filter and a build up of engine gunk, so i spent a couple hours with it and switched the fuel filter, oil change, and went to local car parts store and bought a fuel filter cleaner and ran it through a tank of premium. That was in may havent had a problem since.
see if you can do it all yourself, hyundai dealer basically was going to do the same and wanted someething like $600
Old Feb 23, 2010 | 09:20 AM
The ECU will detect a problem and put the car in a "limp" or "safe" mode. RPM max may be 2,000 allowing you to "limp" home. Hope this works out OK.
Old Feb 23, 2010 | 09:38 AM
cpatel529's Avatar
cpatel529
P1217 is overheating. The mechanic was an idiot and was diagnosing the wrong issue.
Did notice the smell of burning coolant. Car is on its way to Nissan.
Chi
Old Feb 25, 2010 | 05:57 PM
bobbyz350's Avatar
bobbyz350
had this happen to me and my car came out of the sickness but my mph gauge was off 3-4 mph maybe because of the gear swap i did
MAsSIVrOOM
Oct 20, 2023 10:50 AM
etkms
Jun 19, 2022 06:30 PM
Calinismo350z
Sep 14, 2015 04:04 PM
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
