2nd gear notchy feel & linkage noise
Old Apr 9, 2010 | 12:52 PM
albaugh81's Avatar
albaugh81
Default 2nd gear notchy feel & linkage noise
I get a notchy feeling when going into second gear I gotta pull it little harded into place sometimes could this be a shifter alignment issue? Also going into second gear I also hear shifter linkage noise from under the car. I'm hoping all I gotta do is pop off the boot and make sure everything is tight & for the shifter linkage some all purpose grease.
Thanks
Old Apr 9, 2010 | 02:01 PM
dinon's Avatar
dinon
I'm having the same issue. Sometimes it goes into 2nd smoothly, most of the time it makes a 'clunk' noise and has a notchy feel. I'd really like to hear a possible cause for this before I head into the dealer so I know what I'm working with...
Old Apr 9, 2010 | 03:37 PM
johnha209's Avatar
johnha209
i have a hard time going into second sometimes when the car is just starting up.. what i do is instead of going straight from 1 to 2nd gear.. i go from 1.. then shift towards neutral.. then into second.. i dont go all the way to neutral though.. just move the shifter towards N and then down into second.. hope that helps.. =)
Old Apr 9, 2010 | 04:19 PM
F34RL355's Avatar
F34RL355
sometimes its a little notchy on my 08
Old Apr 9, 2010 | 04:59 PM
pjfernan's Avatar
pjfernan
Default linkage noise
I just bought a 2008 350z with 10k miles and sometimes it has a linkage noise going from 1st to 2nd.
Old Apr 9, 2010 | 05:35 PM
mistanismo's Avatar
mistanismo
This is relatively normal for the Z transmission. I wouldn't worry about it, the notchyness will occur in 2nd the most from my experiance... seems pretty random as well, but obviously more so when the car is cold.
Old Apr 10, 2010 | 08:43 AM
albaugh81's Avatar
albaugh81
Thanks man this works now I can drive with no one looking at me strange plus this takes care of the shift linkage noise.
Old Apr 10, 2010 | 11:26 AM
mistanismo's Avatar
mistanismo
Noise should not be audiable outside the cabin, at all, and it's more something you feel than you hear... if it's that loud, i'm going to say it's a problem.
Old Apr 10, 2010 | 11:57 AM
AFD350Z's Avatar
AFD350Z
mine does the sssaaame isht..i hate it so friggin bad..i've never owned a stick that does that...its the only thing i hate about my car..
Old Apr 15, 2010 | 12:01 PM
niZam's Avatar
niZam
For daily driving i usually skip shift to 3rd. In my mind it saves on the clutch and tranny.
Old Apr 16, 2010 | 01:13 AM
kennylin888's Avatar
kennylin888
I started to experience this issue in these couple of days, specially when the car is cold. I got 12,255 miles now and I hope that this is normal in our Z.
Old Mar 7, 2011 | 12:59 PM
F34RL355's Avatar
F34RL355
anyone have any follow up on this issue, im going to get it check out at a few dealerships when i pull her out of storage. one already said they dont notice anything typical :P
Old Mar 7, 2011 | 01:49 PM
JDMStanced's Avatar
JDMStanced
same here.
But only little after start up. What i do is i just go from 1st to 3rd since the **** won't go into 2nd lol
Old Mar 7, 2011 | 06:19 PM
archangel72's Avatar
archangel72
Same thing here, 07 base, in for updates
Old Apr 20, 2011 | 09:31 AM
mf_laurent's Avatar
mf_laurent
ahhh! i see im not the only one with this problem. i only get it at a cold start. after a while, it goes away. i drive an 07 base btw! ...its just annoying!
maybe we should all swap out our engines with the GT-R's o.0?!
Old Apr 26, 2011 | 01:48 PM
PeterSellers's Avatar
PeterSellers
I've had my transmission replaced 4 times, and all of them did this.
Obadabot
Jun 18, 2023 11:31 PM
sherm
Apr 11, 2020 05:21 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
