Gas light on WITH gas
Old May 11, 2010 | 08:35 PM
Armlocker's Avatar
Armlocker
Default Gas light on WITH gas
At startup occasionally the gas light will be ON and the needle will be at empty even though i have over half a tank. DTE will be flashing but showing a high (accurate) number. Ive read through many "fuel sending unit" threads, is this a different symptom of the same problem? After driving for a few minutes the gas needle slowly goes up to the right level. It never used to do this and its happening more frequently lately. Anybody had this problem??
Old May 11, 2010 | 08:58 PM
vics350z's Avatar
vics350z
DUDE Im glad I found this post I have been trying to find owners that have the same problem as me. You fuel gauge will just get worst especially when its below the half and the reason that is because our cars have 2 fuel sending units and one of them is bad the one that measures from E-1/2 tank. Have you noticed that when its above the 1/2 it works great and when it falls below it start tripping. I took mine to the dealer and the idiots could not find what was wrong with it when I told them what was wrong but because the car didn't do that when the had it. They didn't fix it so I called Nissan care and they told me that if enough people report the same problem they might issues and recall for this problem to our Z's. Other Nissan car have this problem already reported to them but not ours yet. SO Call NISSAN CARE @1-800-647-7261 lets get this on recall when you call make a big deal about it and hopefully more people will call I have posting ever where about this..
Old May 12, 2010 | 05:49 AM
R350Zz33's Avatar
R350Zz33
my z will never get to the full line now for some reason it will be somwere between both and it will be totaly full (gas comming out the fill hole) and it will still read there till i drive a few miles it will move up but never hit the full line and theses readings are all on level surfaces
Old May 12, 2010 | 06:03 AM
Armlocker's Avatar
Armlocker
Will do vics. So as suspected this IS another sending unit failure? Mine is an 2004 long past warranty so whats the cost on the item that needs replacement? OEM or aftermarket? I'll be doing the install myself.Thnx!
Old May 12, 2010 | 09:31 AM
vics350z's Avatar
vics350z
I would tell you to go OEM so you can save your self some problems. They run about 100.00 per. sending unit from the dealer. But Call nissan care maybe you can get it for free.
Old May 12, 2010 | 10:19 AM
VO...'s Avatar
VO...
Administrator
My 2006 Nissan Frontier does this exact same thing!! I've been trying to figure out WTF was wrong with it.
Old May 12, 2010 | 11:32 AM
vics350z's Avatar
vics350z
Other Nissan cars are affected too like the frontier and the armada and some altima. I just filed a complaint to the National highway safety commission another thing you can do is call Nissan care 1-800-647-7261
Old May 12, 2010 | 11:56 AM
JasonZ-YA's Avatar
JasonZ-YA
Download FL.PDF from the FSM for your year model Z:
https://my350z.com/forum/maintenance...anual-fsm.html
-J
Old May 12, 2010 | 02:51 PM
VO...'s Avatar
VO...
Administrator
I'm calling tomorrow...
loudtoyz
Apr 6, 2023 04:52 AM
liqalu04
Jan 2, 2022 12:58 PM
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
samansharif
Sep 25, 2015 12:31 PM
