What's up with my oil pressure?
Old Jun 29, 2010 | 05:09 AM
ajw101's Avatar
ajw101
Default What's up with my oil pressure?
For about the last 2000 miles, my oil pressure gauge has been maxed out. I swapped the oil shortly after it started happening. I'm running Mobil 1 now. Any idea what could be causing this besides a broken gauge/sending unit? There are no other symptoms. I have since been autocrossing with no problems. Engine speed doesn't seem to make any difference, and the oil level is fine.
It's a 2003 with about 39,000 miles.
Old Jun 29, 2010 | 05:11 AM
ajw101's Avatar
ajw101
Here's a pic. Not that you should need it. Has anyone else heard of this problem?
Old Jun 29, 2010 | 05:25 AM
djamps's Avatar
djamps
Looks like a broken sender or gauge. If you track your car, I recommend aftermarket gauges/sending unit. The OEM units are prone to error/failure.
Old Jun 29, 2010 | 06:02 AM
evets's Avatar
evets
My 2007 350Z came new from the dealer with my oil guage 'pinned' like the OP's. As stated, it was a problem with the sensor wiring. Nothing to do with Mobile 1 oil.
Old Jun 29, 2010 | 06:07 AM
ajw101's Avatar
ajw101
Did you get it fixed?
Old Jun 29, 2010 | 06:14 AM
winchman's Avatar
winchman
Stuff like this makes me really curious.
You have this really nice car, and the engine oil pressure runs along in the normal range for however long you've had the car, then goes completely nutso, and you KEEP DRIVING IT FOR 2000 MILES before thinking that something might be wrong that you should do something about.
I'm not only curious, I'm absolutely AMAZED.
Old Jun 29, 2010 | 06:24 AM
ajw101's Avatar
ajw101
Well, there were no other problems/symptoms. No sense in being an alarmist. I had replaced the filter again, and the oil seemed to be flowing properly, so I assumed it was the gauge or sender. As you see above, my inclination was correct.
Old Jun 29, 2010 | 09:58 AM
winchman's Avatar
winchman
But the outcome could have been VERY expensive if the bad sender had hidden a real problem with the oil system. The bad sender also sends erroneous info to the warning light, so you would have had no warning of impending doom.
But, as my wife says, the worst thing that can happen almost always doesn't.
Old Jun 29, 2010 | 10:34 AM
Gingervitis526's Avatar
Gingervitis526
Try hitting the gauge, no joke... thats what works for me. If it gets pegged I just tap the top of it and it falls to where it should.
Old Jun 29, 2010 | 01:17 PM
Faulty oil pressure sending unit is a common problem. Replace it.
Old Jun 29, 2010 | 01:53 PM
NismoZ_840's Avatar
NismoZ_840
Only works though if you're this guy...
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
sales@czp
Sep 23, 2019 03:30 PM
