Tomei 268 Cams
Old Nov 28, 2003 | 05:31 PM
  #61
spazpilot's Avatar
spazpilot
Originally posted by g356gear
What is a Greddy e-manage worth?
you can get one for 300-400 but then you will have to buy the support tool (software) or the e-01 programer and tune it. Its a great unit and easy to use. had one on my eclipse and will have one on the Z.
Old Nov 28, 2003 | 06:46 PM
  #62
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
For anyone interested, we are currently running specials on the E Manage (as well as Greddy Profec B Spec II bosot controllers FWIW).
Prices are:
Greddy EManage with support tool - $389.00 shipped in the 48 states.
Ignition harness - $32.00
Injector harness - $29.00
Pressure sensor with harness - $120.00
Ignition harness is not really needed on the Z, as you cannot advance timing with it, only retard timing 9good for boosted guys though).
Old Nov 29, 2003 | 05:35 AM
  #63
mjedens's Avatar
mjedens
Default A/F
Got ECU back yesterday from TS and A/F ratio still in high 14's below 5000 rpm's! Any ideas??? Adam, should I go with larger injectors and an emanage? I'm not giving up on TS, but this is a big "pain in the ***"! I'd be willing to bet that I can remove or install our ECU faster than anyone out there!!!
Old Nov 29, 2003 | 06:28 AM
  #64
PhoenixINX's Avatar
PhoenixINX
Default Re: A/F
Mike - I'm pretty comfortable in saying you're going to need injectors. I felt like this before the motor went together, sorry for not making a recommendation sooner.
As for the emanage, I do believe even Greddy is having issues with it on their car. Call Greddy directly, and see how they are doing with the product on the 350.
Old Nov 29, 2003 | 07:10 AM
  #65
Z1 Performance
Former Sponsor
How are tyou mearuing the A/F...is this on the dyno?
Can you post (or email me) a link that just shows the A/F ratio from the runs?
Old Nov 29, 2003 | 10:39 AM
  #66
BigTwin's Avatar
BigTwin
Default Re: A/F
Has anyone measured the duty cycle on the stock injectors yet?
Old Nov 30, 2003 | 02:17 AM
  #67
mjedens's Avatar
mjedens
Default Adam
The A/F measurement is from a dyno - measured from the test pipe. I'll contact you Monday morning with charts,etc. I'm out of
state and won't return until this evening!
Chris, I'll give you a call this afternoon as I pass thru Nashville.
Old Nov 30, 2003 | 07:51 AM
  #68
PhoenixINX's Avatar
PhoenixINX
Default Re: Adam
Don't just call me, let's do lunch!
Old Nov 30, 2003 | 08:16 PM
  #69
Guru's Avatar
Guru
Default Re: Re: A/F
YOu can measure and datalog this with the e-manage. I believe Greddy has worked out most ofthe bugs on the e-manage for the 350Z. Like my STi, the e-manage does not allow you to advance timing but it is still a very powerful tool with many features for around the same price as a much more basic S-AFC II.
tm9293
North East Marketplace
13
Oct 17, 2015 09:14 PM
B Esquire
Sep 24, 2015 07:52 AM
EnjukuRacing
Drivetrain
Sep 14, 2015 11:15 AM
