350EVO..........3.9 Final drive
Old Nov 13, 2003 | 05:55 PM
Juztin's Avatar
Juztin
I'm sure as hell interested! I can use some shorter gears to make up for the 20"s Only question though is how much???
Old Nov 13, 2003 | 06:02 PM
dwnshift's Avatar
dwnshift
Yes anything is possible.........I might have this wrong but... part of 6th gear is actually part of the main shaft in the tranny... so that would very costly and time consuming.
But anything is possible.
Old Nov 13, 2003 | 06:24 PM
failsafe's Avatar
failsafe
....for your health
BJ- how many people are you looking for? And once you get them how long for production?
Old Nov 13, 2003 | 06:38 PM
little_rod's Avatar
little_rod
But you guys did change 6th gear, so why can't it be readjusted?? Guess that would be kinda custom, though, but it would definitely be worth it to anyone who actually drives on the street(interstate).
Old Nov 13, 2003 | 06:39 PM
dwnshift's Avatar
dwnshift
The more the marrier!!!!
The more e mails I ge teh better the case I can present.
I will try and nail down pricing tomorrow.
We have more suprises coming soon fro 350EVO.com
Old Nov 13, 2003 | 06:40 PM
dwnshift's Avatar
dwnshift
We have not changed any gears.
Old Nov 13, 2003 | 06:46 PM
little_rod's Avatar
little_rod
Well, you have adjusted ratios. That is what I mean. Can 6th gear be adjusted(changed, whatever) like you did with the rest of the gears(1st-5th) to make it the same or taller than the orginial 6th gear?? That is, can you do it.
Old Nov 13, 2003 | 06:50 PM
dwnshift's Avatar
dwnshift
Yes we adjusted the ratios with the new final drive....but all the gears are the same in the transmission.
I thin for what you are looking for you would need this new final drive set up and a taller 6th gear.
Old Nov 13, 2003 | 06:54 PM
raceboy's Avatar
raceboy
Damn, I just switched the diff!!! Aaarrrggg!!! How much? PM me.
Old Nov 13, 2003 | 07:00 PM
little_rod's Avatar
little_rod
OK, how and where could I get that?? That would make me interested in this final drive, if I could get the same or preferably taller 6th gear than stock.
Old Nov 13, 2003 | 08:01 PM
PoWeRtRiP's Avatar
PoWeRtRiP
WOW ive been waiting for something like this to come along. looks great i cant wait to see some numbers off these. Maybe a 12 sec na z ? Oh well im just dreaming here. Heres a suggestion since it takes the ts ecu reflash to really get the most out of these gears why dont you offer a package deal like a ts ecu reflash with the gears and say a ported throttle body thrown in? Im in so long as the price is not too steep and a package will definitely help out.
Old Nov 13, 2003 | 08:28 PM
spazpilot's Avatar
spazpilot
Now I guess its not running anywhere in the 100 to 300 price range like the fords and chevys hu?
Old Nov 13, 2003 | 08:38 PM
KrazY-2K's Avatar
KrazY-2K
Great news. We should start seeing some more low 13-sec N/A Z's now
Old Nov 13, 2003 | 09:24 PM
350Z_Redline's Avatar
350Z_Redline
I already have a mid-low 13 sec N/A Z. My plenum's on the way and the TS ECU will be soon after. Tranny's grinding, so a light weight flywheel will be going in with the new one. Add this final drive to the mix and I'm thinking mid-low 12's . Needless to say I'm interested it the price is reasonable.
Old Nov 13, 2003 | 09:40 PM
350z4steve's Avatar
350z4steve
keep em coming
Im def in if the price is right! PM sent
Old Nov 13, 2003 | 09:46 PM
ElvishasaZ's Avatar
ElvishasaZ
wow who needs a turbo to get into the 12's now? Im guessing with a few good bolt-ons and flywheel/pully mods your car should do high 4's 0-60 at least.
Old Nov 13, 2003 | 09:54 PM
zzzya's Avatar
zzzya
Will there be any options for us 5AT owners? I would be interested if the max speed for 5th gear stayed close to where it is now for gas mileage purposes.
Old Nov 13, 2003 | 10:38 PM
  #38
IndySmooth's Avatar
IndySmooth
Other than reduced gas mileage, what are the possible side effects / downsides to this? Long term included.
How much should we expect for installation?
Old Nov 13, 2003 | 11:52 PM
  #39
syf0n's Avatar
syf0n
very, very, VERY interested!
Old Nov 14, 2003 | 01:15 AM
  #40
joust75's Avatar
joust75
Can someone explain the pros and cons of this final drive adjustment?
If it means quicker acceleration, wouldnt it mean quicker shifts? I already hate how quickly I go through first gear.
Would this make our first gear even shorter??
