350EVO..........3.9 Final drive
Old Nov 20, 2003 | 05:07 AM
  #101
FLY BY Z's Avatar
FLY BY Z
Originally posted by Jeff@Performance
We charge $350.00 max for the install and set up. It could be a bunch cheaper, just depends how much time it takes to set up the lash for the ring and pinion.
So how many hours would you say you would charge?
Old Nov 20, 2003 | 10:01 AM
  #102
Mr B's Avatar
Mr B
Don't worry Jeff. You'll soon get to install one along side the Nismo LSD I'm gonna get from you.
Old Nov 20, 2003 | 03:06 PM
  #103
Jeff@Performance's Avatar
Jeff@Performance
Performance Nissan
4 hours or less. We would charge real time, and if it takes less will pass on the savings.
Old Nov 20, 2003 | 06:25 PM
  #104
Z8M's Avatar
Z8M
Not bad at all. I'd pay that for a gear swap.
Mr Potato Head, if you wanna visit Cali during the holidays, I'll meet you @ Jeff's dealer . I'm actually only minutes away..
Old Nov 20, 2003 | 07:05 PM
  #105
FLY BY Z's Avatar
FLY BY Z
Why don't you come to San Antonio? The most I will have to pay for labor is 120 dollars and the same goes for whoever does this mod with me.
Old Nov 21, 2003 | 08:06 AM
  #106
dwnshift's Avatar
dwnshift
Today is the last day for the pre order special.
Just a reminder.
Old Nov 26, 2003 | 06:39 PM
  #107
daking350's Avatar
daking350
This mod will definitely affect your Speedometer right???How will we correct that??
Old Nov 26, 2003 | 06:44 PM
  #108
dwnshift's Avatar
dwnshift
No it does not effect the speedo. Wheel speeds on the 350Z and the G35 are taken off of the wheels speed/ ABS sensors on each wheel.
Old Nov 26, 2003 | 07:27 PM
  #109
zzzya's Avatar
zzzya
When do you expect to have something for the 5AT vehicles? Do you know what the comparison top speeds would be for each 5 gears? I may be very interested if the ratios look ok for some long trips in 5th gear.
Old Nov 26, 2003 | 09:34 PM
  #110
DLin05's Avatar
DLin05
I sent you guys an email awhile back still awaiting a reply...
Old Nov 27, 2003 | 06:05 AM
  #111
dwnshift's Avatar
dwnshift
D
I have you down on the list. I will be going through the list next week and calling everyone. We are tryig to get a lot squared away in a shirt time. I should hopefully know an expected time of delivery also.
For the 5AT owners we can do the Nismo diff with the ring and pinion and it will go right in.
Old Nov 27, 2003 | 08:04 AM
  #112
daking350's Avatar
daking350
I am interested in these but after X-mas..
Old Nov 27, 2003 | 09:31 AM
  #113
ricochet's Avatar
ricochet
Default Looking forward to it
I also shot off an email. Very interested in the final drive.
Old Nov 27, 2003 | 10:03 AM
  #114
FLY BY Z's Avatar
FLY BY Z
Can you guys stop posting just to say you sent an email or PM? That would be helpful to a lot of us who see the thread bumped back up and for nothing. Thanks!
Old Nov 29, 2003 | 12:51 PM
  #115
Dom's Avatar
Dom
Do you have numbers to compare before/after installing the final drive?
0-60, 1/4mile, track times etc?
Old Nov 29, 2003 | 04:12 PM
  #116
ricochet's Avatar
ricochet
Default 0-60, 1/4 mi times
Yeah, also curious about times. Especially if 60mph won't be had until third gear. What amount of time is tacked on to getting to sixty due to shifts to 2nd and 3rd? 2/10 sec? I think with an N/A bolt on setup it would still be tough to get under 5 sec. Any ideas?
Old Nov 29, 2003 | 04:18 PM
  #117
ElvishasaZ's Avatar
ElvishasaZ
I believe the Final Drive is a 10% gear reduction over stock not that this (assumption) is correct but for example if you are pulling a 0-60 @ a 5.4 reducing that time 10% would make it a 4.86 not that it translates to that......but anyway it does make for some curious speculation all things being equal. (including traction)
Old Nov 30, 2003 | 11:24 AM
  #118
dwnshift's Avatar
dwnshift
We have done a couple of 1/4 mile runs with a G Tech when the weather has been decent.
The quickest I did wasa 13.8 and the slowest of the three was a 14.1.....all runs had wheel spin off the line and shifting to second.
From what I have seen the bigger differences with this set up will be your 0-100 or 60mph on up accel.
By all means I am no drag racer.
Old Dec 8, 2003 | 12:14 PM
  #119
zillinois's Avatar
zillinois
Dwnshift could you tell me what the 60 MPH Cruise RPM is for this setup? I'm selecting cams and they want to know what the car's rpms are at 60mph in 5th gear.
Thanks
Old Dec 8, 2003 | 01:12 PM
  #120
dwnshift's Avatar
dwnshift
Is this in a 6speed manual?
