350EVO..........3.9 Final drive
Old Dec 8, 2003 | 02:32 PM
  #121
zillinois's Avatar
zillinois
Yes. 6 speed manual. Just need to know what the rpms are at 60mph in 5th gear (with the ring and pinion installed) if you could. Thanks
  #122
PropaGanda's Avatar
PropaGanda
He typed 60mph cruise in 5th so I would venture to say he is asking about the auto??? ::Shrug::
Old Dec 8, 2003 | 02:40 PM
  #123
FLY BY Z's Avatar
FLY BY Z
They may not know it is a 6 speed or for some reason want a 1:1 ratio for whatever they are doing. Either way, I think 60 would be right around 3K in fifth. I could def. be wrong. Maybe 3100. Hell, go drive it!
Old Dec 8, 2003 | 02:52 PM
  #124
zillinois's Avatar
zillinois
Yeah thanks mr potato head I didn't think of that duh! I need the rpms with the ring and pinion installed. If I had it I would just go drive it.
Old Dec 8, 2003 | 02:54 PM
  #125
dwnshift's Avatar
dwnshift
If i was back at work I could tell you real quick. I ll get the answer.
Old Dec 8, 2003 | 04:27 PM
  #126
FLY BY Z's Avatar
FLY BY Z
Oh sorry it should be around 3450 in fifth at 60 with the gears if stock is 3050 at 60 in fifth.
3.91*3100=12121
12121/3.53=3434
Old Dec 8, 2003 | 04:57 PM
  #127
zillinois's Avatar
zillinois
Thanks Mr P.H..
We'll see how close you came when dwnshift replies.
Old Dec 8, 2003 | 06:07 PM
  #128
FLY BY Z's Avatar
FLY BY Z
Thanks Mr P.H..
Gee whiz thank for the confidence.
Old Dec 9, 2003 | 11:26 AM
  #129
dwnshift's Avatar
dwnshift
Should have stuck with your first guess................drum roll please!
Its right about 3075-3100 RPM
Old Dec 9, 2003 | 11:56 AM
  #130
zillinois's Avatar
zillinois
Most appreciated Dwnshift. This will help greatly in my cam selection process.
Yeah, the first guess is always the one to go with. That damn math just gets you thinking too much
Old Dec 9, 2003 | 12:30 PM
  #131
FLY BY Z's Avatar
FLY BY Z
Well my second guess was based of a stock gearing guess and that was wrong. Garbage in garbage out.
Old Dec 9, 2003 | 02:22 PM
  #132
uro279's Avatar
uro279
How does this relate to your cam selection process?
thanx
Old Dec 9, 2003 | 02:30 PM
  #133
zillinois's Avatar
zillinois
Gearing shifts the rpm range of your engine. Cams have an rpm range which they are best suited. So, I needed to know how much the gearing shifted that range. I plug all this into a dyno simulation program I have to select the best grind, given the VQ's bore, stroke, cfm, gearing etc.
Old Dec 9, 2003 | 03:15 PM
  #134
FLY BY Z's Avatar
FLY BY Z
Don't keep your results secret.
Old Dec 9, 2003 | 04:40 PM
  #135
zillinois's Avatar
zillinois
I am presently inputting all the data to the build the engine so it will be a little bit before I can give any info out.
Old Jan 30, 2004 | 09:01 PM
  #136
phile's Avatar
phile
I don't do alot of highway driving, but what rpm would I be cruisng at in 6th gear around 80mph?
Old Jan 30, 2004 | 09:13 PM
  #137
OCG35Coupe's Avatar
OCG35Coupe
Originally posted by little_rod
I understand what you are saying, but that is not the point of my post. Most people on this board will spend most of their time on the street, not the track. I am sure this is a wonderful mod for the track and I would love the 1st-5th gearing on my street car. But in an interstate cruise, it will cost you mpg cause the gearing will make the car run at a higher rpm.
All I was saying that while 6th is useless on the track, it is not useless to most people that own the car. Your gearing, with a taller 6th would be the perfect setup, and I would back that up by definitely buying that setup and I am sure I am not alone. Is it possible??
You are not alone. I have been wanting a shorter final drive, and a taller overdrive gear forever.
Old Jan 30, 2004 | 09:43 PM
  #138
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
yeah but the cost of tearing down a tranny to replace a single gear.....you're getting into BIG buck territory.
This has obvious benefits, and only a minor tradeoff IMHO
Old Jan 30, 2004 | 09:55 PM
  #139
daking350's Avatar
daking350
What kind of difference will this make in say 1/4 mile times??Cause I know 1st and 2nd gear when your boosted are REALLY short as it is..
Old Jan 31, 2004 | 09:02 AM
  #140
FLY BY Z's Avatar
FLY BY Z
I have maintained from the beginning that I do not think this is a good mod for drag strip or a car that sees much highway. This will be no doubt good for the road course. But off the road course you are looking at more shifting, worse mileage, more wear and tear, etc. We will only know when it's tested. I think the Z has too short of gears already. I still want to swap out rears with an auto touring. Somebody help me!
