Z33Art V3.0-LS1/TH400 Swap
Old Sep 12, 2011 | 09:28 AM
  #301
Quamen's Avatar
Quamen
So after a long weekend of thinking about what the heck was up I have determined that it had to be my spark plug gap. Reading through my engine management manual they specify that the spark plug gap be .022" for anything over 10psi or 12:1 compression ratio. My car was running at about .036" gap and I run just over 12.5:1 compression.
My car was struggling a bit on the top end like misfire and all my logs show all engine parameters to be in great working order. However, based on Electromotive's explanation of the spark plug gap, I am thinking I was seeing some weird ignition problem with blowout or arcing. Since then I have gapped the plugs at .022" and I am going to put the Mickey Thompson's on and do some good street tuning.
I've come to realize though that my TH400 is an absolute power hog and is running at about 25% parasitic loss . The motor is consuming in the 530-560 crank horsepower range worth of fuel but I bet it only puts down in the low 400whp range. Once I am done street tuning I am going to take it to the track and see what it does. Maybe go back to the dyno some time after that.
Old Sep 13, 2011 | 02:06 PM
  #302
Royal_T's Avatar
Royal_T
Originally Posted by Quamen
Come on T... You know me...
It is a custom mount that I cut myself out of billet aluminum. It is very light weight and installed perfectly!
hahaha I know you custom everything.. Do you happen to have a pic of the mount you can send me..
Old Sep 15, 2011 | 06:45 PM
  #303
Quamen's Avatar
Quamen
Snap! There is definitely a sub eleven second run in it once the car is tuned!
Old Sep 15, 2011 | 08:45 PM
  #304
bbs350z's Avatar
bbs350z
look at that 60' time!!!!
Old Sep 15, 2011 | 08:47 PM
  #305
eltness350's Avatar
eltness350
The Untouchable
hell yea d!! my drag radials held togetha!!
Old Sep 16, 2011 | 01:32 PM
  #306
Cass007's Avatar
Cass007
Love it... break it, build it and then beat on it
Old Sep 17, 2011 | 12:19 AM
  #307
bbs350z's Avatar
bbs350z
saw your sexy *** car driving down layton the other week! hope you recover soon so we can all cruise before the snow sets in dude
Old Sep 17, 2011 | 09:01 PM
  #308
Quamen's Avatar
Quamen
One of my runs from the other night. Working on getting the footage of my 11.213 run but this is all I have for now.
http://www.youtube.com/watch?v=fCVTIgKpcAM
Old Sep 17, 2011 | 09:07 PM
  #309
OldManZ350's Avatar
OldManZ350
Very Nice........
Old Sep 18, 2011 | 07:21 AM
  #310
binder's Avatar
binder
ya, awesome 60'. What size/brand tires are you running?
Old Sep 18, 2011 | 07:31 AM
  #311
Quamen's Avatar
Quamen
305/35/18 Mickey Thompson ET Streets.
Old Sep 18, 2011 | 07:36 AM
  #312
0jiggy0's Avatar
0jiggy0
Did it feel like you solved the spark issue?
Old Sep 18, 2011 | 08:53 AM
  #313
Quamen's Avatar
Quamen
Nope. Car sputtered after 5,000rpms at full throttle. I am going to regap my crank sensor.
Old Sep 18, 2011 | 09:18 AM
  #314
binder's Avatar
binder
sob, i need an automatic. I run those exact tires and can't hook for crap with my os giken twin disk.
What do you have the camber on the rear set to? any other ninja tricks to get them to hook or is it just that nice auto trans?
Old Sep 18, 2011 | 09:33 AM
  #315
Quamen's Avatar
Quamen
Camber is set to OEM specs right now. I found 16-17 psi was the sweet spot for tire pressure to dead hook on my car. The biggest benefit for me was being able to preloaded the drivetrain.
Old Sep 18, 2011 | 10:05 AM
  #316
Quamen's Avatar
Quamen
What horsepower? Tire pressure?
Old Sep 18, 2011 | 10:14 AM
  #317
binder's Avatar
binder
523hp at 13psi but i'm at 17psi now. I also found best traction was 17-18psi but i've never had "good" traction. I usually spin all the way through first with my fastest 60' at 1.9. Usually right at 2 seconds which is sad.
Old Sep 18, 2011 | 01:17 PM
  #318
eltness350's Avatar
eltness350
The Untouchable
r u doin a good burnout?? bigger burnout - harder they grabbed for him
Old Sep 28, 2011 | 11:57 AM
  #319
Quamen's Avatar
Quamen
A set of Hoosier drag radials are on their way for my 15" drag wheels! Also managed to find a way to get more brake bias to the rear so I can launch at a higher rpm! Hoping to hit the track one more time this year and break into the 10's and hopefully pull the fastest 60' on the overall list!
Old Oct 2, 2011 | 04:34 PM
  #320
Quamen's Avatar
Quamen
Hoosiers are mounted and on the car. Also modified the brake system so now I can launch at 3,200 if need be! 1.4xx 60's here I come! Should have more word on the spark issue tomorrow.
