Differential: should i get an LSD?
Old Oct 7, 2010 | 10:59 AM
RobV_350Z's Avatar
RobV_350Z
Default Differential: should i get an LSD?
i have a base model 06 350z and someone told me that i dont have the Limited slip differential. my question is should i get it...i like to drive around quickly around town and plan to eventually practice in some track days. what would be a big difference if i get an LSD installed, is there any cons to installing the LSD?
Old Oct 7, 2010 | 11:35 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
Nothing but upside to installing a real (aftermarket) LSD
Whether your car has the (useless) Viscous LSD or an open LSD depends on the trim level. Everything except the base got an LSD
Old Oct 7, 2010 | 02:22 PM
duro78's Avatar
duro78
change your gear ratio while your at it also. Sometimes you can can a used pumpkin with both
Old Oct 7, 2010 | 02:54 PM
RobV_350Z's Avatar
RobV_350Z
thanks for the replies, but might i ask what exactly, or how exactly it would help me in corners and launches? does it just provide more traction or what exactly? how will i notice?
Old Oct 7, 2010 | 03:00 PM
Z1 Performance
Former Sponsor
http://auto.howstuffworks.com/elsd1.htm
Old Oct 8, 2010 | 10:27 AM
scotts300's Avatar
scotts300
An upgraded LSD will help dramatically in anything competitive. From the context of your posts, you probably wouldn't ever notice it on the street, so don't waste your money if won't ever take it out to a track.
Your burn out:
My burn out:
Old Oct 8, 2010 | 12:44 PM
JasonZ-YA's Avatar
JasonZ-YA
^ i lub dat pic!
-J
Old Oct 9, 2010 | 08:35 AM
nismofreak1208's Avatar
nismofreak1208
wow, very nice pic, loving the little dark black burnout lines way off in the distance lol. scotts300, what diff are u running, 1.5, 2 way?
Old Oct 11, 2010 | 07:17 AM
scotts300's Avatar
scotts300
NISMO 1.5 way with WPC-treated plates at 90% lock: http://www.wpctreatment.com/
Lots more you can read here: https://my350z.com/forum/autocross-r...erentials.html
Old Oct 11, 2010 | 08:02 PM
bbs350z's Avatar
bbs350z
competitive driving REQUIRES an lsd, if you do get one, get clutch type like kaaz, quiafe, etc. the factory viscous system is garbage
Old Oct 11, 2010 | 08:40 PM
JasonZ-YA's Avatar
JasonZ-YA
^ quaife is not a clutch type.
its helical gear unit..
-J
Old Oct 12, 2010 | 03:00 PM
scmtkings4's Avatar
scmtkings4
recently on hard starts, my tires spin a bit before grabbing traction
back then i didnt experience this problem
would this be a sign of my LSD going out? my tires are fairly new, less than a year old about 5000 miles.
or perhaps i need to have my alignment corrected? (on my 3rd set of wheels)
Old Oct 12, 2010 | 03:08 PM
JasonZ-YA's Avatar
JasonZ-YA
^ u sure its not wheel hop???
search on here for rear diff bushing leak...its a black silicone leak from the subframe bushing that holds the diff...
the stock vlsd is worthless i feel after about 50,000 miles and thats very subjective....its fluid and once it shears and becomes not so viscous then its an open diff from there.....i found it to break free quite easy..
-J
Old Oct 12, 2010 | 06:08 PM
plumpzz's Avatar
plumpzz
no, its dirty diff fluid. ive had it happen to me a lot. once you swap it out, it feels great for 10k miles then it shakes again.
Old Oct 13, 2010 | 09:09 PM
scmtkings4's Avatar
scmtkings4
-J
yeah i dont think its wheelhop. its def not vicious enough to be wheelhop
the spinning im referring to doesnt last all that long. on hard starts you hear a bit of tire squeal before i actually start moving. This isn't even on launches. This is only on hard starts.
My car didnt do this before. Only in the last year or so. Had the car for a little over 3 years. I'll look up on the rear diff bushing leaking.
I'll look into this too. This sounds like a possible remedy. Thanks
Old Oct 13, 2010 | 09:22 PM
Originally Posted by Z1 Performance
Excellent reference.
I have yet to figure out why Nissan made a 350Z without LSD. Seems like LSD should be a given - where a CD player is frivolous. Read about LSD. What it does and does not do.
Old Oct 18, 2010 | 01:58 PM
zerosec's Avatar
zerosec
i say everyone should have an LSD installed on the Z ! its like a must if you want to enjoy your ride.
i personally have the Nismo LSD ,car feels great but i do suffer from terrible sounds coming out of the pumpkin , specially when i try to park...
i guess its something very common when u have a Nismo lsd
Old Dec 10, 2010 | 11:29 AM
nismofreak1208
bump for an old thread but I had a question, would getting a kaaz 2way diff be enough for running drift runs but also support auto-x to?
Old Dec 10, 2010 | 11:36 AM
Z1 Performance
Former Sponsor
you would not want a 2 way lsd for auto-x use
a 1.5 way would be the best of all worlds for combined drift/auto-x
Paul.
Oct 16, 2015 07:34 PM
seagrasser
Oct 11, 2015 03:27 PM
RiujinZero
Sep 25, 2015 01:19 PM
3vilbunny
Sep 13, 2015 12:31 PM
