03 05 guys how much oil do you burn?
Old Oct 25, 2010 | 10:02 PM
terrasmak's Avatar
The 05 uses none and has 57k on it. The 03 uses 1 quart every 4k and now has 120k on it. Its burned the same amount of oil since i bought it with 37k 4 years ago. Also i burn 1/2 quart a day when on the racetrack.
Old Oct 26, 2010 | 02:05 AM
unit5alive's Avatar
unit5alive
Smile
03..not a drop!
Old Oct 26, 2010 | 03:52 AM
laser-g's Avatar
laser-g
so I take it is normal on some VQs I'll mention it to the dealer but I think I know the answere already.
Old Oct 26, 2010 | 06:14 AM
sir captian's Avatar
sir captian
Originally Posted by laser-g
damn so what is wrong with mine? I know the dealer is going to say it is normal but I realy don't think it should burn half the oil in 3k miles. so if I did syn. oil and do an oil change at 5k miles with out toping up I would be low on oil?
Your car is fine,Every time I get my oil changed I check the dipstick the same day and it is always at the halfway point,that means its full.The dipsticks in these cars are weird though and my car is a 2006.I dont know if the dipstick changed from 2003 to 2006.
Old Oct 26, 2010 | 06:23 AM
marco_mendoza's Avatar
marco_mendoza
I have an 03 89k no oil consumption. My friend J3dz has an 06 with 90k + and it eats oil.
Old Oct 26, 2010 | 06:24 AM
scotts300's Avatar
scotts300
No, not until 07'. The oil drains out of the heads and past the dipstick, so you have to wait 10 minutes or so with the car off to get an accurate reading.
Old Oct 26, 2010 | 07:09 AM
laser-g's Avatar
laser-g
I check it in the morning so it sits over night. would I have any issues if I dont top it up and leave it at 1/2 way?
Old Nov 1, 2010 | 10:07 AM
IDrm350's Avatar
IDrm350
Driving habits can effect oil consumption right?
Old Nov 1, 2010 | 10:13 AM
tylerxfire's Avatar
tylerxfire
shouldnt
Old Nov 1, 2010 | 10:55 AM
STL 350Z's Avatar
STL 350Z
05, 93k miles, manual... burns no oil.
Old Nov 1, 2010 | 12:48 PM
terrasmak's Avatar
Yes
Old Nov 1, 2010 | 01:02 PM
laser-g's Avatar
laser-g
thing is I don't drive my car all that hard. I could understand if I was always redlinging when shifting but I don't.
Old Nov 16, 2010 | 11:26 AM
juelz86z3303's Avatar
juelz86z3303
Question
yeah i can't really say i have had mines since 2002 no oil buring but i recently notice the oil being low from my gauge but as i check the dip stick seems aaccurate i changed my valve covers tried to read my cams and the lobs is still polished at 170,000 replaced vc gaskets and put on new covers and did a oil change . i just think its natural wit our cars. some burn some dont. but it may be the oil we choose too i notice a lot of mobile 1 users dont have oil burnig problems wit they z's
Old Nov 16, 2010 | 11:37 AM
laser-g's Avatar
laser-g
cool thanks just replaced VC and changed my oil to mobil 1. I will continue to monitor mine.
Old Nov 16, 2010 | 06:12 PM
JOMZSHAKES's Avatar
JOMZSHAKES
i have a 03' and im running castrol syntec euro formula-0-30w
mine burns a lot, the oil light will start comming on during harsh braking/accell
in about 5000 miles into an oil change.i have a short ram and dual exhaust.
im at 40,000 miles and its getting worse since the last 15,000 miles.
i added a catch can and noticed it fills up pretty quick.
i live in redwood city CA, and it gets pretty hot like 90+ degree's a lot.
my engine bay gets so hot my ground wires "stillen" turned like a burnt orange
color when they used to be clear.
im switching my oil to a "REAL synthetic oil" and getting amsoil 0-30w.
i researched and everyone said castrol syntec is a real synthetic, but amsoil told me different, said it used the phrase fully synthetic which also means its a synthetic blend that uses a different base oil.
im also getting a nismo thermosat, nismo radiator cap and amsoil coolant
which is proven to drop engine temperature significantly.
got amsoil powersteering fluid which is simply there ATF fluid.
and motul rbf600 dot 4 brake and clutch fluid to work under better heat conditions.
im adding headers and i know they add a lot of heat to an engine bay and im hoping this will balance it out.
ill have to keep posting to see whether the amsoil eliminates my oil burning symptoms.i hope a hot hot engine isnt what causes oil burning
Old Nov 16, 2010 | 06:17 PM
JOMZSHAKES's Avatar
JOMZSHAKES
oo yea and for all you that have been trusting mobil 1's good name in oil,
there synthetic oil is GARBAGE now.
they switched over to a crappier base oil like 5 years ago and kept there prices in a good range for max sales. Id like to know if anyone can help me prove this...
under used oil analysis' "UOA's" on our engines i remember them being pretty bad, but almost anyone you talk to thinks there oil is the **** or something.
Old Nov 17, 2010 | 06:28 AM
omsin523's Avatar
omsin523
^^search there's a thread on mobil one
Old Nov 30, 2010 | 12:57 PM
  #38
rich2342's Avatar
rich2342
I just had my oil changed and I asked the mechanic if he could check to see if it was low due to the terrible dipstick.
He told me after draining it was low 1.25 quarts. I had used Castrol Sythetic and had about 4,000 miles Plus one track day in the mid-summer.
Should I be concerned?
Obadabot
Jun 18, 2023 11:31 PM
apex locator
Jul 23, 2021 02:27 AM
