Strut bar clearance issue
Old Oct 28, 2010 | 11:14 AM
SlidewayZ33's Avatar
SlidewayZ33
Default Strut bar clearance issue
Hey guys, i have a twin turbo'd 03 350z w/ Kinetix V+ intake mani and 5/16th plenum spacer. My stock strut bar cant clear without hitting the hood. Does anyone know which strut bar will clear?
Thanks!
Old Oct 28, 2010 | 11:44 AM
Barnabas's Avatar
Barnabas
National Z Club President
cusco... here is mine
I think GTSpec will as well.
here is a link to the exact model http://www.vividracing.com/catalog/c...z-p-19773.html
Old Oct 28, 2010 | 11:58 AM
terrasmak's Avatar
My stock fits fine with the stock hood and V+ intake.
Old Oct 28, 2010 | 02:24 PM
Pig Pen's Avatar
Pig Pen
Why both? The point of the Kintetix Racing V+ is to replace the stock plenum without the need of a spacer. Am I missing something? If it gives you better performance, I'm all ears....
Old Oct 28, 2010 | 02:34 PM
Well just take it off.
Old Oct 28, 2010 | 03:07 PM
agunter33's Avatar
agunter33
I got the v+ and kintix said not to get a spacer...
Old Oct 29, 2010 | 05:28 AM
Pig Pen's Avatar
Pig Pen
So do I. The entire point of the Racing V+ is to increase air flow by reshaping the air cavity intake. The Kinetix plenum works FINE with my stock strut bar and the gain speaks for itself. I'd consider ridding yourself of the spacer. I think it actually may be a warranty issue with Kinetix to have one on WITh their plenum.
Old Oct 29, 2010 | 05:43 AM
BoomerZ33's Avatar
BoomerZ33
try the cusco strut bar like Barnabas suggested. if it still won't clear try using those thick washer spacers.
Old Oct 29, 2010 | 11:34 AM
350ZGTS's Avatar
350ZGTS
i had the same setup and i had to sell my motordyne spacer
if i was you i would go with the motordyne MREV 2 manifold and your motordyne spacer, thats what im doin and its the same gain !
then you can clear any strut bar.
Old Oct 29, 2010 | 06:27 PM
SlidewayZ33
im sorry, i think i have a diff manifold. maybe its not the V+, its all black if that helps...sorry!
Old Oct 30, 2010 | 02:17 AM
Pig Pen's Avatar
Pig Pen
Does it look like this?
Old Oct 30, 2010 | 09:21 AM
SlidewayZ33
looks just like that!
Old Oct 30, 2010 | 09:47 AM
Pig Pen's Avatar
Pig Pen
Then you have the Racving V+ Plenum. I'd recommend taking the spacer off and enjoy the Kinetix solo! You'll have no issues with your bar whatsoever.
Old Oct 30, 2010 | 10:41 AM
AshMan's Avatar
AshMan
Club Moderator
the Hot Spot
Pig- you aren't twin turbo'd. OP might use the spacer for more air volume? BrazenZ has a specific strut bar on his cause he has a huge spacer.
Old Oct 30, 2010 | 11:01 AM
Pig Pen's Avatar
Pig Pen
I'll have to look up Kinetix's website but I could've SWORN that it said NOT to use a spacer with the Racing V+ since it is composite and prone to flexig a little (as we have both seen, Ash). I know that the Racing V+ can handle some boost, just not sure of the exact amount. If I can find it, I'll post it.
Old Oct 30, 2010 | 12:45 PM
SlidewayZ33
wow, i had no idea that i shouldnt use both together. I will call kinetix on Monday to see if they have any advice. Thanks for the heads up...
is there any benefit to upgrading to the SSV manifold since i am boosted? i know ppl have reported loss in HP during N/A
Old Nov 1, 2010 | 07:47 AM
Barnabas's Avatar
Barnabas
I have the velocity (the one that replaced the SSV) ANd it moved my power up in the power range a couple hundred RPMS. But I have very smooth map and have had 0 issues watsover and power is great (442hp at 9.5 max boost 400 ft lb tq) Stock block setup JWT 530bb
sherm
Apr 11, 2020 05:21 PM
350z82
Oct 1, 2015 06:25 PM
Depravity
Oct 1, 2015 04:49 PM
