synthetic or not
Old Dec 3, 2010 | 01:09 PM
haleo's Avatar
haleo
Default synthetic or not
06 mt with 10k mi. want to change gear box oil , willsynthetic help quiet the noise between 1st and 2nd shift and which oil is best, dealer says all Zs come with synthetic in tranny true or BS
Old Dec 3, 2010 | 01:47 PM
DavesZ#3's Avatar
DavesZ#3
You might want to do some reading on this as there are lots of threads and opinions on the subject.
That being said, all new Zs come with synthetic in trans and diff. You can switch to it, it will help gas mileage for sure. No guarantee on making it quiet or shift smoother. For some people it does, for others it makes it worse. Most popular brands are Redline & Royal Purple.
Old Dec 3, 2010 | 02:17 PM
hellsoldiers08's Avatar
hellsoldiers08
would getting more oem oil be just fine if your not racing? Or is it better if i upgrade to some better oil because over all it makes a bigger differance?
Old Dec 3, 2010 | 02:40 PM
DavesZ#3's Avatar
DavesZ#3
Synthetics are slipperier (sp?) than conventional oils so they are perfect for gear to gear meshing that occurs in the trans and diff. It really has nothign to do with racing or performance.
Old Dec 3, 2010 | 03:01 PM
AJCaron12's Avatar
AJCaron12
Use OEM fluids.
Old Dec 3, 2010 | 03:26 PM
flecko28's Avatar
flecko28
^ +1
i switched to Redline fluids and haven't noticed much of a difference but did not get to the track this summer to really try it but you will be fine staying with OEM.
Old Dec 3, 2010 | 05:07 PM
hellsoldiers08
well im coming up on 30k miles and i heard some people not using the oem oils and they had problems with the transmission. so im like hmm.
Old Dec 3, 2010 | 05:15 PM
DavesZ#3's Avatar
DavesZ#3
The only "required" OEM fluid is for auto trans - using anthing else voids the warranty.
If by "OEM oils" you mean the new OEM synthetic, then by all means you can use that as well as an aftermarket synthetic gear lube.
Old Dec 9, 2010 | 11:47 PM
Nealoc187's Avatar
Nealoc187
if you're NA and not racing then you're just fine with OEM, though something like Redline MT90 is a better oil in some ways, it's better in ways that you probably won't need (i.e. film strength, shear resistence, etc. properties that you won't overwhelm in the stock fluid, so no real necessity to upgrade the fluid.) I don't know the price of the OEM oil though, so if it's close to or exceeds the price of redline, I'd do the redline.
if you are going to be making north of something like 350ft-lb of torque OR racing the car (or both), then I'd be putting a more robust oil in there.
Old Dec 10, 2010 | 11:53 AM
hellsoldiers08
Thank you Neal, that what i was looking for on the answer. My friend with the rx-8 just did the redline and he said he was impressed but worth the extra cost.
Old Dec 12, 2010 | 09:18 AM
The synthetic lubricant debate will go on forever. But I recommend synthetic for operating at temperature extremes. Tucson, AZ for example where summer temperatures are 100 degrees plus.
At the other end is Fargo, ND. If I am driving a vehicle, any vehicle, in sub-freezing temperatures you can bet I am going with synthetic everything.
Old Dec 12, 2010 | 09:25 AM
derekinthez's Avatar
derekinthez
only 10k miles, i doubt changing oil will solve your noise issues
Old Dec 12, 2010 | 11:39 AM
terrasmak's Avatar
Loud shift between 1 and 2 , sounds like your jamming the gears and destroying your syncros. Learn to shift, very simple. Also changing the fluid to some nice Amsoil (very popular) smooths out the shifting slightly. They offer a nice GL4 fluid, i've been running it in mine for 85k miles now.
Old Dec 12, 2010 | 12:04 PM
350ZTheStandard's Avatar
350ZTheStandard
I love Royal Purple, it meets both GL4 & GL5, so this works for both the tranny & rear end in a single product. Unfortunately the price is now $19.00 a quart (3 1/8 for the tranny & 3 pints for the rear end) pricey, but worth it IMO.
https://my350z.com/forum/2003-2009-n...questions.html
check out post 16
Old Dec 12, 2010 | 07:08 PM
Vader007's Avatar
Vader007
Talking Misimformation!
This is so not true, the J-Matic for the auto trans is a spec not a fluid, Amsoil, Redline and Mobil 1 all make a J-Matic meet or exceed fluid. Moss/ Magnasion act, ever here of it?
Old Dec 12, 2010 | 07:53 PM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
u mean Magnuson–Moss Warranty Act
Old Dec 13, 2010 | 09:54 PM
Steve-O Z33's Avatar
Steve-O Z33
Royal Purple is GL5 and will eat the hell out of the synchros. It's fine for the differential but DO NOT put RP in the transmission. I made this mistake and noticed my transmission did not want to go into gear. I changed that crap out in a week.
Old Dec 14, 2010 | 09:31 PM
350ZTheStandard
I had this is my 6mt for over 3 years with NO PrOBLEMS.The bottle states will meet GL4 & GL5, just changed out all the fluids in my z car today, oil, tranny, rear end, clutch, & pOwer steering.
Maybe you got something spechul!!!!!
seagrasser
Oct 11, 2015 03:27 PM
Stevo Z
Oct 3, 2015 09:14 PM
smithmt3
Sep 11, 2015 08:25 PM
