question concerning putting an engine in my car
Old Dec 11, 2010 | 07:33 PM
future_gohan's Avatar
future_gohan
Default question concerning putting an engine in my car
Okay, i purchased a 350z pretty cheap, but it has no motor, no ignition, or ecu.
I'm buying a vq setup from a friend of mine and said i can have whatever i need to get it to run correctly in my car.
Now question is, what all do I need to get it to run? I hear you need a lot like th antenna stuff in the back aswell, slightly confused, this will be a track only car so if i unplug all that stuff what would happen?
Thanks for answering the questions! thankss
Old Dec 11, 2010 | 08:08 PM
derekinthez's Avatar
derekinthez
uh, a motor, an ignition and an ecu
Old Dec 11, 2010 | 08:38 PM
headhunterx's Avatar
headhunterx
If you have to ask those kind of questions You shouldn't be trying to do what you are trying to do...
Old Dec 11, 2010 | 08:40 PM
future_gohan
Lol yes i should, I've been told i need a bunch of different sensors and stuff from the interior for the engine to run propertly, and sense this is my first 350z, I just want to make sure to grab them all when i get the motor. Its not complicated?
@derek - thats what i originally thought that was all i needed.
Old Dec 11, 2010 | 08:42 PM
future_gohan
Because is this true?
" In the 03+ Nissan line-up of vehicles the ECU must see this signal but so does the IPDM (Intelligent Power Distribution, Module), the BCM (Body Control Module), and the NATS control module. What this means is that if you want to run a Nissan VQ35DE engine into other type of car (like a 240SX or 240Z) you will need to have the ignition key, ignition switch, FM Antenna modulator, the NATS module, the IPDM, the BCM, the ECU, and all the wiring harnesses to each of these (almost every harness in the car) and they all have to be taken from the same donor car."
Old Dec 11, 2010 | 08:54 PM
headhunterx
Here Goes:
Attached Thumbnails question concerning putting an engine in my car-facepalm013.jpg
Old Dec 11, 2010 | 09:21 PM
future_gohan
That helps a lot
Old Dec 11, 2010 | 09:26 PM
headhunterx
Well maybe this will help you out a little better:
Attached Thumbnails question concerning putting an engine in my car-181148-triple_facepalm_super.jpg
Old Dec 11, 2010 | 09:48 PM
You can download a factory service manual for free. THat will be very helpful.
Old Dec 11, 2010 | 11:12 PM
terrasmak's Avatar
Standalone ECU
Old Dec 12, 2010 | 08:06 AM
kramykram's Avatar
kramykram
wow
Old Dec 12, 2010 | 03:56 PM
future_gohan
Standalone ECU
is there anything cheaper to go with other than a full standalone? Like a rom tune of some sort?
Old Dec 13, 2010 | 11:56 AM
R350Zz33's Avatar
R350Zz33
It's not an Evo or sti
lol rb26dett done your welcome
etkms
Jun 19, 2022 06:30 PM
Ace2347
Sep 22, 2015 03:12 AM
Katie93
Sep 15, 2015 05:57 PM
RyansZ33
Sep 15, 2015 05:54 AM
torchkc
Sep 11, 2015 08:26 PM
