may be a newb question
Old Jan 12, 2011 | 11:27 AM
redzblackh's Avatar
redzblackh
Default may be a newb question
ok so i recentley got a new clutch and flywheel (JWT). and before i replaced the last one i hadnt driven the car for a couple months cause i rode my bike every day. now im noticing that its kind of hard to put it into reverse, 1st and sometimes 2nd gear when im downshifting. i dont REMEMBER it being like that before my first clutch blew. am i just being paranoid or is this something i should get checked out?
Old Jan 12, 2011 | 12:29 PM
350ZTheStandard's Avatar
350ZTheStandard
Who did the work, did you change out the tranny gear fluid also & I also notice that when it's cold I have some issues getting the 6MT to smoothly shift until the tranny juices warm up. This is an inherent issue with all Datum's & Nissan's to the best of my knowledge.
Old Jan 12, 2011 | 02:46 PM
redzblackh's Avatar
redzblackh
yeah, the fluid was all switched out
Old Jan 13, 2011 | 09:32 AM
350ZTheStandard
Who did the work???
Old Jan 13, 2011 | 09:35 AM
georgek350z's Avatar
georgek350z
welcome to the world of aftermarket clutches and flywheels ! my car does the same with a stage 4 . its just the way it is brotha . its normal . just get in the habbit or putting it in gear before the vehicle comes to a dead stop makes life a lil easier .
Old Jan 13, 2011 | 09:42 AM
kramykram's Avatar
kramykram
probably just need to adjust the pedal on the floor. 12mm nut and a pair of needle nose.
Old Jan 18, 2011 | 08:59 PM
redzblackh's Avatar
redzblackh
thats what im saying man, if its not almost at a stop, i can put it in 1st unless i force it
Old Jan 18, 2011 | 09:06 PM
Ronin82's Avatar
Ronin82
doesnt sound to abnormal.
no anybody else with a Z, drive, compare and contrast
Old Jan 19, 2011 | 08:32 AM
ocdz's Avatar
ocdz
granny shifting, not double clutching like you should...
Seriously though have you tried double clutching in these situations? Both my Z and pick-up do this when cold down shifting.
Push in clutch, put in neutral, release clutch, push clutch, put in gear.
boom! double clutch works wonders.
Old Jan 19, 2011 | 09:42 AM
redzblackh's Avatar
redzblackh
ill try that. thanks
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
