Is my idle normal? (pics inside)
Old Feb 8, 2011 | 05:27 AM
venmichaels's Avatar
venmichaels
Default Is my idle normal? (pics inside)
I just purchased this car.
its an 04 350z Roadster 5A/T
with 100k.
Currently the car shakes and sputters at idle.
Is your idle this low?
Old Feb 8, 2011 | 05:28 AM
dbrown's Avatar
dbrown
look like it to me...
Old Feb 8, 2011 | 06:11 AM
hellsoldiers08's Avatar
hellsoldiers08
hmm seems about right to me... it in the ball park that for sure. I say if if shuttering and shaking, i would just replace spark plugs and maybe do a injector cleaner/replace injectors. I bet someone else probably has a better solution. Also are you throwing any codes?
Old Feb 8, 2011 | 07:12 AM
mvp2765's Avatar
mvp2765
yah, get a tune up and always do an oil change after you buy a used car.. CHeck your air filter also.
Old Feb 8, 2011 | 08:21 AM
daniel.sepe's Avatar
daniel.sepe
yeah my idle is around there somewhere. looks good
Old Feb 8, 2011 | 09:11 AM
DavesZ#3's Avatar
DavesZ#3
With A/C off and wheel straight ahead, that's normal.
Old Feb 8, 2011 | 12:10 PM
venmichaels
it shakes only at idle. does good under acceleration...
Old Feb 8, 2011 | 06:33 PM
PerfZ's Avatar
PerfZ
Shakes while in gear or in neutral/park?
Old Feb 8, 2011 | 08:39 PM
venmichaels
it shakes in gear, idle, or neutral..
its driving me insane...
Could this be from oil in the spark plug hole??
sometimes it will also randomly shake under full throttle on the highway..
Old Feb 8, 2011 | 11:34 PM
sportbiketed's Avatar
sportbiketed
Is it just the shifter that shakes while you're driving?
Old Feb 9, 2011 | 12:32 AM
cbcm2435's Avatar
cbcm2435
yeah mine does this too, but i can turn on the ac and it stops
Old Feb 9, 2011 | 05:22 AM
350Z_Al's Avatar
350Z_Al
Check for Vacuum leak too.... Mine idled real low, and rough after having a vacuum leak after installing a plenum spacer.
Old Feb 9, 2011 | 05:41 AM
venmichaels
The motor shakes.. actually the entire car shakes. you can feel the vibrations.
Car is completely stock..
A/c on doesnt help..
Old Feb 10, 2011 | 12:27 PM
venmichaels
car is starting to shake while driving.. the motor is shaky as he'll.. help
Old Feb 10, 2011 | 12:29 PM
venmichaels
the shaking isn't from my idle. it's idling fine.. could my motor be screwed??? it still pulls pretty hard under acceleration.. but it shakes
Old May 17, 2011 | 08:23 PM
Nissan FREak's Avatar
Nissan FREak
Did you ever find Out what was wrong with the Car? Venmichals.
Old Jun 17, 2011 | 12:03 PM
J 0 K 3 R's Avatar
J 0 K 3 R
Originally Posted by venmichaels
car is starting to shake while driving.. the motor is shaky as hell.. help
motor mounts are notorious for getting lose over time with these cars, the engine is probably rattling against the frame.
Old Jun 17, 2011 | 02:01 PM
Cass007's Avatar
Cass007
hellsoldier already asked, but I will ask again... any codes or a check engine light? Seems like you have a misfire.
liqalu04
Jan 2, 2022 12:58 PM
350Z_Al
Oct 29, 2020 07:44 PM
sales@czp
Sep 23, 2019 03:30 PM
codek
Sep 28, 2015 03:03 AM
