Oil Pressure Sensor Thread?
Old Feb 19, 2011 | 05:53 PM
spent's Avatar
spent
Default Oil Pressure Sensor Thread?
Anyone know what the thread on the oil pan for the oil pressure sensor? This thread is going to be the same as the g35 oil pressure switch, correct?
Thanks
Old Feb 19, 2011 | 06:34 PM
turbotoy's Avatar
turbotoy
Most foreign cars I have seen for pressure are 1/8" BSP.
Old Feb 19, 2011 | 08:07 PM
shakuya88's Avatar
shakuya88
The stock presure sensor is 1/8" BSP, I can confirm that. Now my question is on the pan how would get a pressure reading, unless you mean to replace the OEM sensor. If replacing, changes are new sensor will be 1/8" NPT, most aftermarket sensors are this. What is your trying to do exactly? Be glad to help
Old Feb 20, 2011 | 03:40 AM
spent's Avatar
spent
240sx vq swap... The actually engine is out of a g35, so atm, there is a oil pressure switch in the pan... I wanted to add a oil pressure gauge so I didn't know what thread I needed for the sending unit... I don't recall seeing a 1/8 BSP sending unit, so should I drill and tap a new hole? The 240sx gauge cluster has a oil pressue switch light so I could actually hook that up too...
Old Feb 20, 2011 | 08:22 AM
shakuya88's Avatar
shakuya88
Use this
http://gtmotorsports.com/product.php...cat=266&page=1
It comes with a 1/8" mbsp to 1/8" mnpt, adapter block with 2 fnpt ports and 1 fbsp That way you can still use factory sensor along with aftermarket ones. Can always block off what isn't needed either.
Old Feb 21, 2011 | 03:15 PM
spent's Avatar
spent
http://www.summitracing.com/parts/ATM-2269/
I'll think I'll save some cash and go with that one lol... Thanks guys
Old Nov 6, 2020 | 03:20 PM
Ralli's Avatar
Ralli
By the way, which oil is better to pick up?
Old Nov 6, 2020 | 08:21 PM
travlee's Avatar
travlee
Master
9+ year dead thread
Old Nov 9, 2020 | 10:40 AM
Kalasin's Avatar
Kalasin
Well, it is necessary to look specifically for the wear of the machine and there are many different factors that must be taken into account when selecting such oil. I can only advise you to study the details of the oil type for g35 https://carfluidsexpert.com/top-5-be...-infiniti-g35/ and only so already determined on the oil. I myself have done so and know that this is probably the most accurate way will be, in addition, you will already know exactly what you choose from those that exactly fit, just there are nuances, which are just the same and described here. There are several options and you can already choose from them. Good luck.
Kevin Skene
Feb 26, 2018 10:38 AM
alfee
Apr 19, 2013 10:15 AM
ljastangs21
Oct 28, 2011 09:13 AM
binder
Mar 5, 2011 03:32 PM
sleeperZ69
Apr 14, 2006 08:46 AM
