Still blowing coils...
Old Feb 20, 2011 | 05:31 PM
spent's Avatar
spent
Default Still blowing coils...
VQ 240sx swap... had it up and running, tried to hook up tachometer by splicing 240sx tach input to the negative side of a coil. Now the car keeps blowing coils even after I removed splice and I don't know what to do. I replaced all of the coils that were shorting out and now the new ones I put in are blowing. It is not the ecu... I sent that out to have it checked and the ecu is fine. The only code the car has been throwing is the P0300 or w/e, misfire...
I don't know what else to check? I did all the wiring for this swap myself, so I'm comfortable with basic auto electrical, just don't know what next...
Old Feb 23, 2011 | 08:06 AM
spent's Avatar
spent
There seems to be slight resistance between the igntion power circuit and ground... I suspect this may be the source of my problem?
*This resistance only exists when the ECU is plugged in. However, the ECU is fine, and I also have another working ECU and the same thing happens...
apex locator
Jul 23, 2021 02:27 AM
m_0g
Jun 3, 2021 10:05 AM
Juztin
Nov 22, 2015 07:03 AM
brooklyn
Feb 10, 2003 02:35 PM
