Tranny grind every gear still unresolved help me
Old Mar 23, 2011 | 06:32 PM
zerostyle's Avatar
zerostyle
Default Tranny grind every gear still unresolved help me
ok i posted a thread about 3 weeks ago, got deleted for title. anyways
heres the story...got motor replaced, tranny was dropped from engine and hung for at least 5 days...got new engine, and right from the get go the gears were grinding...
1. its every gear
2. clutch is getting fully pressed in ( just to rule out someone saying i dont know how to shift)
3. its not the grinding you get when your not fully pressing clutch, you can still go into the gear, but youll get the vibe, youll hear the sound as well.
4. only way to avoid is shifting under 3k or pushing clutch in letting rpms drop and going into gear slow.
5. sometimes when 1st and reverse when the clutch is pressed and im trying to get going and tapping the gas rather than just holding it down (hope you guys what i mean) the tranny will get like stuck and stay in a grinding "mode" if you will, until i let go of the clutch. this only happens when starting out whether in 1,2, or reverse and only when tapping the gas.
6. i feel like gear placement is different...5th and 6th dont feel as far upper right and lower right as before..they feel closer in...or maybe im overthinking..
7. tranny fluid was changed 200 miles ago to rule that out with mt90 85w-90 mt5 or w.e. the recommended is for the car i cant remember but i made sure 2344 times its the correct one so thats ruled out as well..
8. another member had same problem after engine replacement....if im not mistaken, he replaced clutch, slave cylinder, throwout bearing so those parts are ruled out as well...
i think thats it. please HELP OUT ME. my latest hunch has been pilot bearing...went on some vette forums guy had pretty much same problem and everyone was leaning towards pilot bearing...
thanks any help is appreciated
Old Mar 23, 2011 | 07:25 PM
bbs350z's Avatar
bbs350z
sounds like synchros if it doesnt grind going in light. try running castrol syntorq 75w-85.
Old Mar 23, 2011 | 07:47 PM
SuperBlack350z's Avatar
SuperBlack350z
when i dropped my tranny out, and installed everything back in, i didn't align the shift plate correct and was grinding every gear to. then i removed the shift boot area again and just kept realigning it until its stopped. not sure if it will help your problem but it sounds similar to mine.
Old Mar 23, 2011 | 08:18 PM
zerostyle's Avatar
zerostyle
I spent 80 bucks on royal purple... im not draining and changing lol. I really dont think its that...
Old Mar 23, 2011 | 08:20 PM
zerostyle's Avatar
zerostyle
K superblack i will get the shop to try that since they installed.
Old Mar 25, 2011 | 04:59 PM
zerostyle's Avatar
zerostyle
tried shifter plate...it helped with me getting that gear placement back how it felt before....however grind is still there....
Old Mar 25, 2011 | 05:22 PM
SuperBlack350z
wait, the gear oil you bought, RP, did you make sure you got GL4? i dont' remember RP made that. only GL5
Old Mar 25, 2011 | 05:54 PM
zerostyle's Avatar
zerostyle
the RP was for gl-4 and gl-5 applications...
Old Mar 25, 2011 | 05:55 PM
zerostyle's Avatar
zerostyle
i really dont think my issue is a tranny oil issue....my transmission was completely fine! dropped the motor, got new one, and from the first shift in the new motor i was grinding
Old Mar 25, 2011 | 06:23 PM
bbs350z's Avatar
bbs350z
^you get alot of grinding with improper oil. alot of guys mix redline fluids i believe. i always used synthetic oils in factory weight such as the syntorq. i hate to say it, but you may need to remove the trans and check if everything is aligned properly.
Old Mar 25, 2011 | 10:36 PM
winchman's Avatar
winchman
Wasn't there a thread here a short time ago where the culprit was a damaged pilot bearing? If they messed it up during the replacement of the engine, it would explain the sudden onset of the problem and the fact that it affects every gear.
Old Mar 26, 2011 | 03:35 AM
SpoilsofWar's Avatar
SpoilsofWar
I had a hard time getting the transmission and engine to mate properly when I was reinstalling my engine after my build.... Had to wrestle with it for a while before it just decided to align and slide right together. But I must admit, it was tempting to use the bell housing bolts to snug the two together after I'd been fighting with it for half an hour or so - This is a major no-go. If your shop did this, chances are theres a misalignment and/or bearing damage. They probably wouldn't admit to doing it, but its worth a shot to ask them. Either way, they need to remove the trans again and inspect all the mating parts.
Old Mar 26, 2011 | 03:44 AM
terrasmak's Avatar
Damaged Pilot or wrong fluid. Gl4/Gl5 compatable fluid is not good for our cars. BTW RP oils are crap, well , good oil for race apps where its replaced every couple hundred miles.
Old Mar 26, 2011 | 04:22 AM
350Zenophile's Avatar
350Zenophile
Why don't you let the shop figure it out since they broke it? Seems pretty straightforward that they fugged something up on install if it was working fine before? What am I missing?
Old Mar 26, 2011 | 08:42 AM
zerostyle's Avatar
zerostyle
Im leaning towards pilot bearing....and i got my motor dropped at nissan and the new one put on at a different shop....it cant be fluid, i had the right fluid prior to the royal purple and it was grinding
Old Mar 26, 2011 | 08:44 AM
zerostyle's Avatar
zerostyle
So the shop i got the install at ive already told him my issues and asked him if he would look at it and hes tryna charge me for labor to drop tranny
Old Apr 14, 2020 | 04:09 PM
Mannyz05's Avatar
Mannyz05
I know I'm 10 years late (almost literally) but what was the issue. I'm going through that right now I also changed the motor and used RP, I'm going to swap it for the redline mix but idk if it's going to fix it
Old Sep 25, 2021 | 01:36 PM
keough's Avatar
keough
did u ever figure anything out or rule out some things?
MAsSIVrOOM
Oct 20, 2023 10:50 AM
sherm
Apr 11, 2020 05:21 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
Ace2347
Sep 22, 2015 03:12 AM
Bodyboarder81
Sep 21, 2015 06:23 AM
