V8 350Z. my 500+rwhp goal
Old Apr 15, 2011 | 07:18 PM
  #81
Quamen's Avatar
Quamen
Originally Posted by bbs350z
^please do! also how much trimming does that speedhut tach require?
Requires quite a bit. Some trimming to the gauge face, some trimming to the back side of the OEM bezel and some trimming to the stock circuit board plastic mounting piece. Takes about an hour or two to correctly.
Old Apr 16, 2011 | 08:19 AM
  #82
Vas_Z33's Avatar
Vas_Z33
I do not have a write up on the harness because sikky is doing it.. its just plug and play for me when i get it back. in about another week or so
Old Apr 16, 2011 | 09:15 AM
  #83
97supratt's Avatar
97supratt
Originally Posted by Vas_Z33
yepp!
I spoke to Rich from WC cylinder heads, my heads are being worked and should be done in 8 days..
Awesome guy to work with. I gave em my goal and the list of mods and we went over the best parts. got the complete head package. I upgraded some more internals as well.. apr heads studs etc..
heres a short list of what i remember :
brand new SB gen.4 L92/ls3 head casting
REV L92 intake valve 2.165
REV ls3/l92 stainless steel exh.val. 1.600x4.930
PEP dual spring w/ titanium retainers
Rock arm stand
ARP pro head series stud kit
ARP cam bolts
CHE precision LS3 rock arm set ( these were 650 alone! for high reving )
CNC stage2.5 porting
street strip 8cyl valve job
I dont remember the cam specs
these are fully assembled.
We talked alot about drivability and he gave me a cam thats not too extreme but not too soft either, so we settled in between. it'll start to make power around 2800 and hold it all the way 6900... with my valve train and high reving bearings as well as the fast, I wanna rev to at least 7-7500K . We will see when tuned.
He said that these were the best street extreme cam. too extreme and it would suffer at idle, and drivability. Ill get the specs when he sends me it
Revving to 7500 will not do that engine any good, actually you won't be making any additional power. The dual valve springs are mainly used for the cam you purchased because of the high lift.
The cams available for LS2/LS3/LS6/LS7/LS9 are tunable in a sense that they will still hold idle to a certain degree. It all depends on what you're building that engine for. If you're building it to create as much power as possible, high lift low lsa LG and England green makes a great cam.
Old Apr 16, 2011 | 10:12 AM
  #84
binder's Avatar
binder
so for cost so far we have:
5500 engine and trans
3500 sikky kit
800 labor
??? extra parts?
So just for the basics to get engine in the car and do all the work yourself would be at least 9k. right? This is sounding a lot more expensive than when we talked last.
Old Apr 16, 2011 | 10:30 AM
  #85
Quamen's Avatar
Quamen
$9k if your lucky. Even doing all the labor yourself.
3500 sikky kit
800 labor
??? extra parts?
Old Apr 16, 2011 | 10:36 AM
  #86
QTB's Avatar
QTB
3500 sikky kit
800 labor
??? extra parts?
No way you can do it that cheap unless you come across some killer deals and even then you'd be hard pressed. Best estimate is $12-15k
Old Apr 16, 2011 | 10:40 AM
  #87
Vas_Z33's Avatar
Vas_Z33
I'm not complaining about cost... I still see this well worth it than building the vq. Much different and unique . IMO well worth it
Old Apr 16, 2011 | 10:51 AM
  #88
Vas_Z33's Avatar
Vas_Z33
Jeff, ur doing the prices from scratch. Don't forget I had a turbo kit , engine, tranny, clutch etc etc.
So for me it's not 10k , bc that stuff is funding my project, that's money already wasted..
To get a turbo set up on a STOCK block running right is about 10 k... N then to built the block to hold 500+.. $$$$. Now that's a waste lol.
The pros out run the cons IMO . Which is why I went this route.
Old Apr 16, 2011 | 11:12 AM
  #89
bbs350z's Avatar
bbs350z
+1 i sold my setup, and still didnt quite cut it.
so far im
3500 gcre built block/heads
700 sikky headers
2500 sikky kit (buying next week)
500 misc ls1 parts/pieces/ecm/tach
350 clutch/flywheel
2100 built t56
400 rad/fans
1000 gtk1000 turbo
estimate $300 on exhaust routing, etc
250 intercooler
100 valve covers
450 manifold/fuel rails
450 injectors + box
used bov, wideband, boost, and ebc from my previous setup
and im probably forgetting something
not to mention i still need more misc parts here and there, crank damper, hp tuners and a tune. it adds up quick, and i got a somewhat decent price on all this stuff
Old Apr 16, 2011 | 12:13 PM
  #90
binder's Avatar
binder
oh i'm not doing it. I'm happy with my 523 pumpgas tune and soon to be 700hp e85.
I was just curious about this prices because when i talked to vas a few months ago it sounded like this would only cost a little over 7k total. It sounded way more than that when i heard the parts list though.
I'm not arguing built block/turbo verses v8 i was just curious what this setup really costs.....personaly it doesn't matter because i'll be pulling 700hp with my own setup
Old Apr 16, 2011 | 12:34 PM
  #91
Vas_Z33's Avatar
Vas_Z33
Focker ^ haha
Old Apr 16, 2011 | 12:45 PM
  #92
binder's Avatar
binder
lol, i'm going through hell right now trying to decide what to do. I want to save money but it looks like sending the stock block in that i have to be built fresh would be better than refreshing my build block. Sucks though
Old Apr 18, 2011 | 12:59 PM
  #93
Vas_Z33's Avatar
Vas_Z33
soem goodies came in
Old Apr 18, 2011 | 01:01 PM
  #94
Vas_Z33's Avatar
Vas_Z33
Old Apr 18, 2011 | 01:15 PM
  #95
Royal_T's Avatar
Royal_T
sooo pretty..
Old Apr 18, 2011 | 01:28 PM
  #96
Vas_Z33's Avatar
Vas_Z33
the heads are pure sex.. polished inside and out hah
Old Apr 18, 2011 | 02:10 PM
  #97
Royal_T's Avatar
Royal_T
^^ looks good bro,, can't wait to see all this put together..
Old Apr 18, 2011 | 02:11 PM
  #98
bbs350z's Avatar
bbs350z
sounds like only a handful of us z owners need a pitchfork and a mullet, im growing mine as we speak
btw sexy heads
Old Apr 20, 2011 | 08:40 AM
  #99
binder's Avatar
binder
the one thing i'm envious over is being able to remove the heads to change head gaskets without taking the whole front of the engine off. That is a huge plus.
Old Apr 20, 2011 | 12:14 PM
  #100
Quamen's Avatar
Quamen
Agreed. If you have ever taken the heads off of a VQ then you understand why this is a huge benefit. With items like the Edelbrock split front timing chain cover for the LS motors you can even do cam swaps with very little disassembly of the motor.
