V8 350Z. my 500+rwhp goal
Old Nov 15, 2011 | 09:46 AM
  #141
bbs350z's Avatar
bbs350z
Originally Posted by Cass007
NICE!! I think my car is on the dyno today, so I will post numbers when I get them and hopefully a graph.
bbs - Just noticed you were able to fit your APS strut brace. Mine won't fit with the stock mani and throttle body
really? mine fits fine, just gotta maneuver the fuel line.
have you thought about adding spacers to the brace and using longer bolts??
Old Nov 15, 2011 | 01:57 PM
  #142
Cass007's Avatar
Cass007
Mine was already up against the hood.
Old Nov 15, 2011 | 02:06 PM
  #143
bbs350z's Avatar
bbs350z
if the glove dont fit...
Old Nov 27, 2011 | 08:29 AM
  #144
Rambo's Avatar
Rambo
^you should relocate your coil packs!
sry to thread jack, did you use the stock coil bracket to do the remount. I will be doing this on my G35 LS6 build. It looks awesome. I am building the motor and the block is all done up. It would be a shame to cover it...
Old Nov 27, 2011 | 01:48 PM
  #145
bbs350z's Avatar
bbs350z
^yup left them on the bracket, drilled the 2 end holes slightly larger and also drilled through the frame, mounted them, extended the wires through the fenderwells and voila, there they go! im gonna do my engine bay in a flat black so the engine really stands out, and fab up a cover to hide the coil packs completely
Old Dec 1, 2011 | 01:16 PM
  #146
Brew_haha's Avatar
Brew_haha
updated pics of my harness
oh and these sexy *** wheels for my m35x vip thing
EEEEEK at that wiring harness!!!!! The idea of relocating the coil pack its a good idea but looks like you will run into clearance problems when you turbo it.
My wiring harness = no tape and lots of RAYCHEM DR25
also included is a version with out raychem and loomed in nylon sleeving
Plug and play!
Old Dec 1, 2011 | 01:18 PM
  #147
Vas_Z33's Avatar
Vas_Z33
clean^!
Old Dec 1, 2011 | 01:22 PM
  #148
Brew_haha's Avatar
Brew_haha
you know it!
Old Dec 1, 2011 | 01:24 PM
  #149
Brew_haha's Avatar
Brew_haha
i like the idea of relocating the coils but there are alot better places to locate them at like the back of the heads you dont run into any clearance problems and they are out of the way of natures elements.
Old Dec 1, 2011 | 02:06 PM
  #150
Cass007's Avatar
Cass007
My harness is done the same way, labeled and everything just like yours. Mine even has detachable sub harnesses for the accessory packages and trans too
Vas... is it running yet?
Old Dec 1, 2011 | 03:23 PM
  #151
bbs350z's Avatar
bbs350z
^logan, turbos in the back, no clearance issues! the coilpacks themselves use weathproof connectors, and my car still has the oem fenderwells and undershroud. plus, who drives these things in the rain lol
  #152
Vas_Z33's Avatar
Vas_Z33
^^^^ hell no! =( the harness is taking longer than thought. I think with sikkys failure + wait and plus what im waiting now.. its been like almost 4 months of downtime just bc of harness. =/ . I'm not gonna even stress it. I just hope it ships soon
Old Dec 2, 2011 | 07:32 AM
  #153
Brew_haha's Avatar
Brew_haha
Vass i told you!!!! Sikky is slow as ****!!! They have been trying to get us to make their harnesses thats one reason, but they are slow to respond about anything we send them. If you can cancel your order with them i can have you a harness built to your specs in 1-2 weeks.
Dimitri i drive mine in the rain all the time its one of my Daily Drivers! So you are doing like a sts mount?
Cass007 - did you use a dakota digital converter for the stock tach? I know you mentioned someone helped you out with the wiring are they on the forum by any chance.
Old Dec 2, 2011 | 07:39 AM
  #154
Cass007's Avatar
Cass007
My understanding is that the Dakota Digital box wil NOT work correctly on our cars. I had my tuner Franz @ Diebold Autosport do both the harness and integrate all the wiring for the dash and the AC. He even has it set up so that my stock idiot lights on the dash will work.
Old Dec 2, 2011 | 08:14 AM
  #155
Brew_haha's Avatar
Brew_haha
Thats what i had heard about the dakota. I just sent you a PM instead of highjacking VASS's thread sorry!!!
Old Jan 11, 2012 | 02:15 AM
  #156
acke15's Avatar
acke15
Updates?!?
Old Jan 11, 2012 | 12:29 PM
  #157
Cass007's Avatar
Cass007
Originally Posted by acke15
Updates?!?
Talked to him via text last week and he said the harness was shipping the next day.
I used to think that my car took forever with the wiring ... guess I was wrong.
Old Jan 11, 2012 | 01:29 PM
  #158
Royal_T's Avatar
Royal_T
Logon,, Don't we have to send you a core for the wire harness? so you can mod it..
Old Jan 12, 2012 | 09:22 AM
  #159
Brew_haha's Avatar
Brew_haha
Yes but only so we can reuse the 3 chassis plugs that are located right next to the battery and fuse box.
Other than the 3 chassis plugs that we reuse from the Z/G harness everything is completely brand new. Those 3 plugs even get new terminals. So you are getting all new wire, terminals plugs, wire and loom. No solder or electrical tape is used with our harnesses. Only adhesive heat shrink, nylon braided wire loom and or rachem dr-25 nothing cheap or half assed. My wiring harness took less than 2 weeks to complete.
Old Jan 12, 2012 | 09:26 AM
  #160
Brew_haha's Avatar
Brew_haha
And in your case since you are doing a drift car we would not even require a core harness. We would set everything up with individual relays fuses and switches, this is what we call our "race option"
