Bleeder valve question.
Old Jul 1, 2011 | 08:52 PM
carlos305's Avatar
carlos305
Default Bleeder valve question.
I put in a new clutch master cylinder today and now i need to bleed the line. But i noticed the shop that installed the clutch/flywheel messed with the bleeder valve a little too much and the wrench slips when i try to open the valve. Is this valve replaceable?
Old Jul 2, 2011 | 08:38 AM
carlos305's Avatar
carlos305
ok so i bled the line, and now the clutch doesn't stick anymore but it wont release the shifter at high rpms. For example: i take out the car in 1st take it to 6k rpms try to shift into second but the shifter wont come out of second with the clutch fully depressed. It happens in any gear not neccesarily 1-2. Please help me this is starting to get frustrating!!! BTW slave cylinder was replaced about 4 months ago aswell.
Old Jul 2, 2011 | 10:09 AM
ehsan's Avatar
ehsan
so what your saying is the clutch is not disengaging?
Old Jul 2, 2011 | 12:37 PM
carlos305's Avatar
carlos305
Yes but only at high RPMS
Old Jul 2, 2011 | 04:03 PM
shiftdrift06's Avatar
shiftdrift06
Assuming the clutch is properly bled.
Adjust your clutch pedal. look in the DIY section on how to.
Old Jul 3, 2011 | 02:25 PM
carlos305's Avatar
carlos305
Does the clutch pedal hieght affect the bleeding process?
Old Jul 4, 2011 | 09:51 AM
carlos305's Avatar
carlos305
anyone?
Old Jul 4, 2011 | 11:08 AM
terrasmak's Avatar
It can, cause your not getting full stroke on the master or slave.
Getting air out of the system is a PITA, having the full proper stroke on the master is a must without a pressure bleeder.
Old Jul 7, 2011 | 05:33 PM
carlos305's Avatar
carlos305
i bled my clutch but i think i still have some air in there, i noticed the clutch height wasn't all the way up so maybe redoing it will do the trick. Anyone know if i can use a vaccum bleeder? if so how would i go about doing this?
this kit specifically :http://cgi.ebay.com/CAR-AUTO-HAND-PO...#ht_698wt_1141
PS: not being pushy but please reply if you have info as i want to do this in the morning. Thanks in advanced.
Old Jul 8, 2011 | 06:27 AM
carlos305's Avatar
carlos305
Come on guys someone's gotta know the answer to this.
Chris350z03
Oct 8, 2023 07:19 PM
Rev_Night
Nov 7, 2020 06:00 PM
allmycarsdie
May 13, 2016 04:38 PM
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
