My SIKKY LS2 install thread
Old Dec 13, 2011 | 04:14 PM
  #461
Barnabas's Avatar
Barnabas
National Z Club President
Originally Posted by Cass007
Got the car up on a lift today at Hill's. Went over all the nuts and bolts to make sure everything was tight. Found a small spot on the pass side header that was rubbing the frame and fixed that.
Found one concerning issue... the Cusco sway has made occasional contact with the front of the oil pan and rubbed a small spot in the side beads . My car is lowered all the way on the coilovers, so that may be the issue. I may have a blown shock up front as well, so that may be a contributing factor. We moved the sway to the rear holes (softer setting) and will see if that fixes it. If not, I may need to bring the ride height up or get a different sway. Frank suggested shorter end-links to restrict travel as well, but I'm not sure where to get those.
Found a small exhaust leak and also realized that JE butchered my APS exhaust. They cut the stock flanges off and put different ones on, which is NOT what I wanted. Now the exhaust is ruined if I ever want to resell it... THANKS SO MUCH BTW, the exhaust is leaking from their flange welds.
I also partially destroyed one of the V-band clamps at the header. Must have scraped it on something. The price of being low and baller I suppose.
Frank put my Zspeed underpan on, fits great and the cut out still lines up with the oil drain. Allows access to where my filter is as well. Down side was that they didn't debur it one bit and it will cut you to shreds if you don't handle it carefully.
The good news... Frank and I bled the old clutch fluid out and refilled with Motul and the clutch is MUCH improved in terms of pedal feel and softness. He also adjusted the pedal engagement down a touch from the very top.
About 800 miles since I brought it home and still loving it
Try the powergrid endlinks chris
http://www.z1auto.com/prodmore.asp?m...ng&prodid=2886
Hope to see you on newyears
Old Dec 13, 2011 | 11:11 PM
  #462
Jagot's Avatar
Jagot
Was going to suggest the Whiteline ones (Aussie site but available worldwide)
http://www.whiteline.com.au/product_..._number=KLC110
or the racecar ones!
http://www.whiteline.com.au/product_..._number=KLC010
The powergrid ones also look good (and a bit cheaper too).
Old Dec 14, 2011 | 05:52 AM
  #463
Cass007's Avatar
Cass007
Nice... Thanks Guys!!
Barney... family commitment on New Years Eve. Your place will be a great time though. Tell the Mid-A to tip one back for me
Old Dec 17, 2011 | 06:01 AM
  #464
Cass007's Avatar
Cass007
So I took a look at the sway bar position relative to the oil pan yesterday with the car on the ground and can see that the bar is maybe 1/4-3/8" away from the pan.... NOT GOOD.
I'm 90% sure I have at least one blown strut up front as well. I am considering swapping the factory struts back on to see if that helps since the TEINs will have to come out for repair anyway.
Any thoughts or input if the end links will solve this issue, or is it the ride height in general, or is it the Cusco sway, or is it the blown strut
Last resort would be to have a shop weld a couple of pieces to the crossmember that would stick out in front of the pan to act as bump stops for the sway bar.
So just like that the car is down till I get this sorted out
Old Dec 17, 2011 | 11:45 AM
  #465
Cass007's Avatar
Cass007
Decided to swap out to the factory struts, so I did it today in my garage... on my back... with hand tools I am too old for this shizz.
Got the stockers back in and although the ride height looks a little weird the sway is further from the pan now. Definitely confirmed a blown strut or both in the front, the sharp rattle I had over bumps or transitions is now gone as is the pogoing effect I was feeling. Now I just have to find a way to get back to the corner of the pan and stick something to it to see if its still making contact or not.
Just like that... the car is back up
Old Dec 17, 2011 | 12:20 PM
  #466
Royal_T's Avatar
Royal_T
Glad to here...
Old Jan 4, 2012 | 10:35 AM
  #467
str8dum1's Avatar
str8dum1
Kinda OT, but any of you guys with VQ harness that you pulled out, any way anyone would sell me the driver's side VVT solenoid connector with a couple inches of wire still attached.
Mine got all buggered up when my cog belt snapped on my vortech and of course having cam issues on that side, so want to rewire that entire connection.
you'll never need again with the LS!
Thanks!
Old Jan 4, 2012 | 11:43 AM
  #468
Brew_haha's Avatar
Brew_haha
We sell them messaged ^^^^
Old Jan 6, 2012 | 08:34 AM
  #469
Cass007's Avatar
Cass007
Got my engine covers back from paint:
My SIKKY LS2 install thread-p1062159.jpg My SIKKY LS2 install thread-p1062160.jpg My SIKKY LS2 install thread-p1062161.jpg
WOOT!!!
Old Jan 6, 2012 | 08:43 AM
  #470
JE's Avatar
JE
Vendor - Former Vendor
Matches perfectly.
Old Jan 6, 2012 | 09:17 AM
  #471
jerryd87's Avatar
jerryd87
looks amazing cass, btw what are you planning for another vq? i see that you have been asking around about some stock blocks lol
Old Jan 6, 2012 | 09:27 AM
  #472
Barnabas's Avatar
Barnabas
lOOKS GREAT CHRIS!
Old Jan 6, 2012 | 09:33 AM
  #473
dikspiel's Avatar
dikspiel
Chestons Toilet
those engine covers dont look like they can hold power
Old Jan 6, 2012 | 09:35 AM
  #474
QTB's Avatar
QTB
Battery charger? lol Hey where did you get your silicone bend off the TB? It looks like more than a 90* bend. I'm getting ready to order my parts but have been debating of doing a 90* or a 135* I'm digging the valve covers and impressed it all match so well.
Old Jan 6, 2012 | 09:47 AM
  #475
Cass007's Avatar
Cass007
www.turbohoses.com
I got a 135* and Franz cut it down to where it needed to be. The clearance is so tight that it had to bend more than 90* to be 4" all the way to intake.
SHHH... its a secret!! I love my new setup and NOTHING will change this car back to a VQ.
lOOKS GREAT CHRIS!
Thanks Barney!!
Next mod is orange wheels
Matches perfectly.
- I buy the can when I get paint done because I know I have OCD issues with things looking a certain way.
Old Jan 6, 2012 | 09:54 AM
  #476
bbs350z's Avatar
bbs350z
Attachment 330173 Attachment 330174 Attachment 330175
WOOT!!!
you engine bay looks like superman lmfao yuo get any vaccuum leaks with that port unplugged from the brake booster?
i went to siliconeintakes.com nice prices and awesome customer service
Old Jan 6, 2012 | 10:00 AM
  #477
QTB's Avatar
QTB
www.turbohoses.com
My VQ (revup) will be for sale in March if you're willing to wait.
Old Jan 6, 2012 | 10:10 AM
  #478
Cass007's Avatar
Cass007
Come on mang... would I do a noob moove like that?!?!?! I put the check valve and hose for that inside the brake compartment, the hose is just sitting there... empty and alone.... forever.... I've already been told my car looks like Optimus Prime, I'm fine with it.
Not sure if the red headed stepchild year will work for me.
Old Jan 6, 2012 | 10:14 AM
  #479
QTB's Avatar
QTB
But we're a gental people
Old Jan 6, 2012 | 10:57 AM
  #480
jerryd87's Avatar
jerryd87
i figured you where just looking to build a 287hp go cart or something =P
www.turbohoses.com
Thanks Barney!!
