My SIKKY LS2 install thread
Old Nov 18, 2011 | 06:20 AM
  #381
Cass007's Avatar
Cass007
I really want to jump on this bandwagon , oh so tempting
Then doooo iiitt!!!
I doubt it will feel slow, but at least it sounds stupid fast!!!
Feels real quick and responsive down low and just not scary up top like with the twins. Its completely different, a leisurely 1st to 4th shift is perfect for around town driving.
Old Nov 18, 2011 | 06:51 AM
  #382
Quamen's Avatar
Quamen
Originally Posted by Cass007
Then doooo iiitt!!!
Glad to hear you are enjoying it! Have you really romped on it yet?
Old Nov 18, 2011 | 10:03 AM
  #383
Cass007's Avatar
Cass007
I have a time or two. The Toyo R888's don't want to give up easily and if I really pound on it the clutch will slip a bit. The throttle response is immediate, the ViPEC eliminates the slight hesitation people speak of with the factory setup. It yanks HARD down low and smoothes out up top. I'm thinking with a little SC or a good cam/heads combo it will be perfect.
Anything over 2500rpm on the tach and people just stare. You can hear me coming from behind you apparently as I see peoples eyes checking the rear view to see what the noise is. I cruised down a city block or two today and was setting off car alarms
The clutch is the first thing on the new mod list, but that would be inevitable even without modding so its no huge deal. I wish I could sell my Carbonetic Twin so help pay for the new clutch.
Time to drink a few beers and do some LS/T56 research.
Old Nov 18, 2011 | 10:05 AM
  #384
Cass007's Avatar
Cass007
Confirming as well that the hard shift from second to third will be delayed without the drill mod
The guy with the red G35 knows what he is talking about. If I try to slam from second to third there is a moment of pressure or resistence before the gear will engage.
Old Nov 18, 2011 | 11:16 AM
  #385
Vas_Z33's Avatar
Vas_Z33
Cass, you should consider getting my clutch and flywheel setup.. When I did my research people loved it on both Na and FI application. It is a beast and holds upwards of 700+. I will txt you some info when i get to the shop. It is a SPEC. with a different flywheel combo.
Old Nov 18, 2011 | 11:59 AM
  #386
Cass007's Avatar
Cass007
Very Cool... thanks Vas!!! Is it a lightened flywheel?
  #387
bbs350z's Avatar
bbs350z
i went and bought lines with 1/8th restrictors from pegasus. but beware cass, the trans cannot come out without removing the motor as a whole (although itmay if you remove the trans and then the bellhousing). i speak from experience
Old Nov 18, 2011 | 01:35 PM
  #388
Cass007's Avatar
Cass007
*****... I thought JE was able to get the trans out to fix the slave when I jacked things up.
Old Nov 18, 2011 | 02:32 PM
  #389
Royal_T's Avatar
Royal_T
You guys really need to give Jason a call at http://www.texasdrivetrainperformance.com/.. I am having a built T56 done by them and they do crazy builds... Thing will shift like a beauty once they are done with it..
Old Nov 18, 2011 | 08:12 PM
  #390
bbs350z's Avatar
bbs350z
id be interested in using a tr6060 eventually. i have a built t56 and im hoping it holds up
Old Nov 18, 2011 | 09:07 PM
  #391
10-E-C-350Z's Avatar
10-E-C-350Z
I wish I knew half of what this Vipec guy does. The EVAP stuff is stumping me to death.
Old Nov 19, 2011 | 05:24 AM
  #392
Cass007's Avatar
Cass007
I will try to get some pics for you to show you how Franz routed it.
Old Nov 19, 2011 | 07:34 AM
  #393
bbs350z's Avatar
bbs350z
Why are you guys running evap? There has got to be an area in your state that doesn't require emissions. I yanked all that stuff, and registered my car in a county without emissions.
Old Nov 19, 2011 | 12:41 PM
  #394
Cass007's Avatar
Cass007
I didn't have too, I just didn't want the wife complaining that the car smelled like fuel. Mine is registered as a parade/show vehicle
Old Nov 19, 2011 | 06:22 PM
  #395
binder's Avatar
binder
carbonetics twin...i might be interested.
Old Nov 20, 2011 | 05:29 AM
  #396
Cass007's Avatar
Cass007
Sitting in my shed in like new condition Jeff... it needs a good home
Old Nov 21, 2011 | 03:24 PM
  #397
Cass007's Avatar
Cass007
I ordered the Zconcepts aluminum underpan today. I will report back as to if it fits or not. Looking for any guidance others may have for a streetable clutch/flywheel combo with stock feel that can handle 600whp eventually and multiple drag strip runs.
Dear Santa...
Old Nov 21, 2011 | 07:24 PM
  #398
Langdonious Rex's Avatar
Langdonious Rex
Check out the Fidanza 7.6 dual clutch. The Camaro5 guys seem to love them and I have one in my room waiting for my LS2 swap. They are under a grand and hold up to 900 ft lbs of torque which should be plenty for your needs.
Old Nov 22, 2011 | 03:48 AM
  #399
10-E-C-350Z
This. I was talking to that fanfoe dude on ls1tech and he said he just ran the evap straight to the intake, no purge vavlve or anything. I will get more clarifiction on this, as I would imagine that running a line from a vented gas tank to an intake would be like creating a vacuum leak but then again maybe not, since this dudes car runs fantastic.
Thanks in advance for the help, Cass.
Old Nov 22, 2011 | 04:22 AM
  #400
Vas_Z33's Avatar
Vas_Z33
^ iam also running my evap to the intake
