Dyno is a heartbreaker
Old Jul 12, 2011 | 04:28 PM
phatchops42's Avatar
phatchops42
Default Dyno is a heartbreaker
So I went on the rollers today. Mods consist of X02 catback, Ichiba TP's, MD 5/16 ,Nismo CAI and heavy *** XXR 521 20's. Done at Element Racing in Ogden, Utah at 4800 Ft and 85 degrees. I was hoping for more but oh well.
Old Jul 12, 2011 | 04:34 PM
etownz33's Avatar
etownz33
Someone on here once told me that a dyno gives you nothing but a number. A number in itself means nothing. How it makes you feel is what is important. There are a ton of variables here. Elevation, temp, humidity, there is so much to factor in. Maybe the combination of parts isn't working well.
Old Jul 12, 2011 | 07:10 PM
You will never win the Dyno Racing Championships with these numbers.
Old Jul 12, 2011 | 07:24 PM
DaveJackson's Avatar
DaveJackson
Master
Too bad you were hoping for more, but if you use this as a starting point and pay them to give you a tune with UpRev or something along those lines you will have this baseline to compare it to.
But, like you mentioned, those 20's ain't helping you out.
Old Jul 12, 2011 | 07:25 PM
Glex25's Avatar
Glex25
I lost alot of TQ and gained very little (if any at all) WHP with exhaust mods when I was NA.
The mod that gave me the most power NA was MD 5/16th spacer with the MREV+ after that it was mostly downhill.
I rather have TQ than WHP any day on a NA setup.
Old Jul 12, 2011 | 08:07 PM
phatchops42
I have a Vortech on the way right now, this was pretty much just a baseline run to see where I am at with my NA mods. Should have listened to everyone else from the start and just went with FI.
Old Jul 13, 2011 | 06:45 AM
pcressey's Avatar
pcressey
Did you dyno it before you started bolting things on, or is this your first time? If so, what did it do stock?
What do you expect to get out of the Vortech? You doing any supporting mods, or just throwing it on the stock motor with a bit better fuel delivery?
Old Jul 13, 2011 | 07:38 AM
PerfZ's Avatar
PerfZ
Also, every dyno will read differently. So you need to stick with the same dyno each time, before and after, and ideally the same weather conditions.
Old Jul 13, 2011 | 07:48 AM
Alberto's Avatar
Alberto
Cranky FI Owner
NA engine at altitude with heavy cheap wheels, what do you expect?
Old Jul 13, 2011 | 07:54 AM
350ZTheStandard's Avatar
350ZTheStandard
FAct, elevation hates the dyno, & you my friend are in the Rocky Mountains.
silverbullet_Z
NA Builds
24
Nov 14, 2015 02:52 AM
seagrasser
Oct 11, 2015 03:27 PM
NissanZcrazy
Sep 23, 2015 07:59 AM
