VDC turns off sometimes because of no circlip?
Old Oct 6, 2011 | 08:43 AM
ztouring03's Avatar
ztouring03
Default VDC turns off sometimes because of no circlip?
So i am going to do a pumpkin swap this saturday with a local. my stock pumpkin for his 4.08 FD pumpkin. Question though he said that his VDC turns off once in awhile, because the mechanic who installed it didnt put a circlip on it. He says it throws off the sensor and so the vdc just turns off.... hmmmm confused here lol. Should i go through with this or how can i fix it so i can have VDC... even though i only drive with vdc when im driving in the rain. Or is there something else that is causing the problem?
sorry if this is something dumb, rather be safe the sorry
Title fixed i hope
Old Oct 6, 2011 | 09:05 AM
VO...'s Avatar
VO...
Administrator
Old Oct 6, 2011 | 09:07 AM
ztouring03's Avatar
ztouring03
Thanks VO hope i can get some help looking to do this swap by sat.
Old Oct 6, 2011 | 11:00 AM
terrasmak's Avatar
If its a C clip , it will only take $3 and 5 minutes to add it. Very good posibility, but the problem is probably in his car.
Old Oct 6, 2011 | 01:01 PM
ztouring03's Avatar
ztouring03
thanks terrasmak... any like on how to install the C clip or little help on that? and i been hearing its probably his car wit the problem... well im test driving on sat to make sure its all good and if so doin the swap right after
Old Oct 9, 2011 | 12:55 PM
dikspiel's Avatar
dikspiel
Chestons Toilet
interesting, my abs malfunctions since i had my lsd installed. i wonder if this is the same issue.
Old Oct 10, 2011 | 01:39 PM
ztouring03's Avatar
ztouring03
its the c-clip. he never go it put on so were the axles connect it moves some the the sensor cant read it so shuts it off... going to get that c-clip put on this week. My ABS, VDC and Slip light all come on.
Dik u might be that on your Z, u can check just jack it up n were ur axles connect see if u can move it towards ur tire u shouldnt be able to.
loudtoyz
Apr 6, 2023 04:52 AM
sherm
Apr 11, 2020 05:21 PM
Depravity
Oct 1, 2015 04:49 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
samansharif
Sep 25, 2015 12:31 PM
