does a vq37hr block bolt up to the de?
Old Oct 28, 2011 | 06:19 PM
iamgus_gus's Avatar
iamgus_gus
Default does a vq37hr block bolt up to the de?
real simple, I just want to know if an vq37hr block bolt up to the de? Im sure it would need a custom tune but no idea if they are a compatible bolt up.
Feel free to tell me to search bc i did but cant spend hours searching and did not find a definitive answer.
Old Oct 28, 2011 | 06:44 PM
Fluid1's Avatar
Fluid1
Will it bolt up to what? The chassis of a DE vehicle?
Yeah, but you'll need a LOT of stuff. It's not worth it
Old Oct 28, 2011 | 06:52 PM
iamgus_gus's Avatar
iamgus_gus
just replacing the bottom end. Theres a vq37hr long block for sale cheap near me and i have a high miles on my z. Thinking of swapping just the bottom end out if it the fitment is correct.
Old Oct 28, 2011 | 07:16 PM
baker0308's Avatar
baker0308
if ur saying break down your de motor and use a vq short block to add your de long block parts to.............. no that wont work at all
Old Oct 28, 2011 | 07:21 PM
iamgus_gus's Avatar
iamgus_gus
kk, i was just checking. I was hoping it would be like B series Honda engines where you could Frankenstein what you wanted. Guess not. Ill just buy a built de block.
Old Oct 29, 2011 | 01:43 PM
bmccann101's Avatar
bmccann101
careful where you buy it from and who you have do the work.
if you buy a built engine, youd might as well add fi.
It will cost you 2k for a used full motor, 3k to install or DIY.
It will cost you 5600 for a built block and a touch more for labor. Or you can install yourself.
either way, if youre not diy...
someone elses headaches on a 64k mile engine swap in costs you 5k, a built engine w labor costs you 8500, and a built engine w a basic FI system will add another 8 k to that but you will have double the hP.
up to you and your wallet.
Old Oct 29, 2011 | 02:47 PM
iamgus_gus's Avatar
iamgus_gus
people on here keep trying to scare me away from FI. I could just go full bolt ons and a tune but i feel like im still spending a couple grand and getting what 30hpish... hard to justify the bang for my buck.
Old Oct 29, 2011 | 09:23 PM
midz350's Avatar
midz350
Yea, run away from FI.
Old Nov 1, 2011 | 05:48 AM
binder's Avatar
binder
FI is expensive on these cars. Just the block alone will cost more than a completed b series engine with car.
vq37 is nothing like vq35 except for the fact that they are both nissan. Other than that it's a completely different beast. I have both sitting on the floor in my garage.
AbrasiveRaysive
Sep 20, 2021 02:29 PM
