Quaife LSD with different final drive ?!! urgent advice
Old Nov 7, 2011 | 11:24 AM
nightcrawler_8's Avatar
nightcrawler_8
Default Quaife LSD with different final drive ?!! urgent advice
hi guys.
quick question, ( i tried to search and didnt find a proper answer )
Stock open diff.
quaife L11 ( manual diff )
works perfect.
now if i want to change the ratios with an auto. from 3.5 to 3.3 .. do u guys think it will fit ?!?!?!
what is the difference between a open manual pumpkin and open auto pumpkin ??!! only the ring and pinion or something else as well.
thanks guys.. your input is appreciated.
Old Nov 7, 2011 | 12:43 PM
drivessidewayz's Avatar
drivessidewayz
It's only the pinion and crown gear that differ. Yes it will fit; plenty of people have done it.
Old Nov 7, 2011 | 12:47 PM
nightcrawler_8
why then quaife have different part for auto ??
does that mean i wont be able to use my lsd ?/?
Old Nov 7, 2011 | 01:24 PM
kno's Avatar
kno
im doing the same thing, is there a difference between the 3.3 and the 3.5? driving wise? i have a 6spd base and the donor has a 5 spd auto touring.
Old Nov 8, 2011 | 01:55 AM
nightcrawler_8
So no one installed it on a 3.3 !?!?!?!?!?!
Old Nov 8, 2011 | 03:47 AM
Cass007's Avatar
Cass007
I have a Quaife and the 3.3 auto gears from a G35. I did a complete pumkin swap, so I am using the G35 auto pumpkin. I was unaware the there different Quaife parts for auto and manual, but the pumpkins appear very similar from the outside, so it should be fine plus many have kept the stock pumpkins and just swapped the final drive gears. You could always check with Quaife directly to be sure.
The difference driving wise is that it allows you to get a bit more out of each gear because its a longer ratio. It is especially helpful for the +500whp F/I guys because it will help a bit with traction as the boost comes on too. I liked it because in day to day driving it meant not shifting quite so much a speeds under 35mph.
Old Nov 8, 2011 | 05:51 AM
nightcrawler_8
Thx for the input.
Would u be able to check if the one u have is the manual or the auto quiafe diff ?!?!
Thx alot..
Old Nov 8, 2011 | 08:27 PM
nightcrawler_8
Bump !!!!! Anyone ?!?!
Old Nov 9, 2011 | 03:36 AM
Cass007's Avatar
Cass007
Originally Posted by nightcrawler_8
Thx for the input.
Thx alot..
I would have no idea and the car is 3 states away currently.
Old Nov 9, 2011 | 07:16 AM
ogiehooker's Avatar
ogiehooker
Default 3.3 vs 3.5
3.3 ring gear is larger than the 3.5.....my shop built a separate base pumpkin or my 5 at, and we discovered the diffeence, so now Im stuck with the 3.5 or having to buy a new auto 3.3 quaife
Call quaife as suggesteed and tell them what you have and what you plan to do, ***, yes, they have many different setups.
Dont screw yourself like I did....I thought I knew what I was doing but didnt..ASK QUAIFE FIRST!
Old Nov 9, 2011 | 02:59 PM
kno's Avatar
kno
thanks for the input!
Old Dec 21, 2011 | 09:34 AM
Ted J's Avatar
Ted J
As it's been stated the 3.3 ring gear is thicker and the diff is different because of that.
Here is a pic I put together to help show why you'd need a different diff. to go to a 3.3 gearing:
https://my350z.com/forum/engine-and-...-pictures.html
Obadabot
Jun 18, 2023 11:31 PM
3vilbunny
Jul 18, 2017 05:10 PM
350z82
Oct 1, 2015 06:25 PM
