JWT Clutch; OEM Flywheel?
Old Feb 2, 2012 | 05:24 PM
rtiid22's Avatar
rtiid22
Default JWT Clutch; OEM Flywheel?
Like title says, would the OEM Flywheel be compatible with a JWT Clutch?
I already have both but I'm growing tired of the chatter and am thinking of just putting the OEM Flywheel back in but I love the pedal weight the JWT Clutch supplies.. Thoughts?
Old Feb 2, 2012 | 06:10 PM
johnwigs's Avatar
johnwigs
yes it will fit... I wouldn't recommend it but it will fit
Old Feb 2, 2012 | 06:40 PM
ZSpeedPerformance's Avatar
ZSpeedPerformance
Vendor - Former Vendor
Chatter as in noise or the car is shaking when you take off from a stop?
Old Feb 2, 2012 | 06:41 PM
dorrifto's Avatar
dorrifto
why wouldnt you recommend it? I am about to buy a new clutch, and I am not going to buying a new flywheel.
Old Feb 2, 2012 | 06:46 PM
Yes you said that 28 months ago: https://my350z.com/forum/vq35hr/4628...-flywheel.html
Old Feb 2, 2012 | 06:48 PM
johnwigs's Avatar
johnwigs
I can live with the drivetrain noise... I actually don't hear alot because of how I drive but thats besides the point
I dislike how the stock flywheel feels after having a JWT flywheel... I recommend aasco flywheel and JWT clutch and 12,000 KG pressure plate. seems to be a good combination and has a nice firm pedal that isn't all numb and mushy
Old Feb 2, 2012 | 08:32 PM
rtiid22's Avatar
rtiid22
Originally Posted by davidv
lmao! I thought i did but didn't find it in my statistics, thanks for finding it.
but that thread never mentioned the combination of stock flywheel with JWT Clutch.
well, I've lived with it for 2 years and I've got disposable income now, so why not.
Old Feb 2, 2012 | 08:35 PM
rtiid22's Avatar
rtiid22
Just noise at a stand still out of gear.. especially loud when the car is warm-hot from driving it hard.
Old Feb 2, 2012 | 08:37 PM
johnwigs's Avatar
johnwigs
that is the input shaft bearing... normal to be loud... maybe should replace trans if it is really bad, does it go away when you push on clutch pedal?
Old Feb 2, 2012 | 08:40 PM
rtiid22's Avatar
rtiid22
Is the aasco flywheel dual mass? I'm looking for quieter solution
rtiid22's Avatar
rtiid22
yeah
Old Feb 2, 2012 | 08:43 PM
johnwigs's Avatar
johnwigs
not a clutch problem... you need a trans... the dual-mass flywheel will not make the noise go away
aasco flywheel is aluminum single piece... great quality!!!
Old Feb 2, 2012 | 08:50 PM
rtiid22's Avatar
rtiid22
are you kidding me! This has been going on for years and now I'm 20k miles out of warranty.. Would neglecting this issue cause mechanical failure?
Old Feb 2, 2012 | 08:56 PM
johnwigs's Avatar
johnwigs
no they are all crap... they make noise brand new and progressivly get worse
Old Feb 2, 2012 | 08:59 PM
rtiid22's Avatar
rtiid22
thanks for clearing that up. I understand the Z's transmission would never be quiet, even my stock made noise but it wasn't too bad.
Old Feb 2, 2012 | 09:01 PM
johnwigs's Avatar
johnwigs
yeah and aftermarket fluid will make it even worse!!! I would just stick with factory 75w-85 MTF
350z82
Oct 1, 2015 06:25 PM
