ls6 350z build thread!
Old Feb 19, 2012 | 04:27 PM
  #61
04.350z's Avatar
04.350z
So today is update day.
finally got to work on the ls6 a bit today and get things torn apart so i can figure out what needs to be replaced cleaned etc.
todays goal was to get the wiring harness labeled correctly and removed from the engine. a few clips were broken or missing but nothing i cant fix or dont need.
second on the list was remove the valve covers and inspect the heads to see what needs to be replaced or cleaned.
they were much cleaner than i expected so i think i am going to refrain from replacing the valve springs and valves for the time being considering how clean the heads are.
but that being said i spoke with Royal_T earlier and after discussing with him what should be done we decided the Texas Speed Torquer V2 was the cam for my particular setup.
next i removed the intake manifold to see what was going on down in the valley
was a bit dirtier than i was hoping looked like most of the dirt was just from being in storage.
but what i didnt like was the white crusty residue near the front of the valley looks to me like coolant so there will need to be more investigating next week on what is leaking or what the issue really is.
i went ahead and cleaned out the valley so that wont need to be done next week. i will remove the cover next week and clean is more throughly.
next i removed the waterpump assembly to clean up before installation.
i will have the pulley painted gloss black to match the coil pack brackets.
next i removed the alternator and ps bracket because i will be purchasing new brackets for both to clean up the bay just a bit.
lastly i removed both motor mounts and the ac compressor which will be set off to the side for now until i can get some ac lines made.
hopefully a few parts will show up this week.
i ordered the lokar 48" throttle cable
and gm performance spark plug wire replacements.
during the week this week while i have some down time at work i will be sanding down the coil pack brackets and the valve covers to they will be ready for paint later in the week.
Old Feb 19, 2012 | 04:43 PM
  #62
Quamen's Avatar
Quamen
Just to get you excited here is the Texas Speed Torquer V2 cam in my car:
http://www.youtube.com/watch?v=MdgZsKdG2CA
Old Feb 19, 2012 | 05:09 PM
  #63
04.350z's Avatar
04.350z
Thanks I think I just got a chubby
Old Feb 20, 2012 | 12:51 AM
  #64
QTB's Avatar
QTB
Originally Posted by Rambo
Where are you putting the PS tank?
I've scrapped all the Sikky stuff and used the OEM Nissan tank and PS cooler. I'm only using the Sikky High Pressure line.
Old Feb 20, 2012 | 05:16 AM
  #65
Royal_T's Avatar
Royal_T
Very nice, and you will like the V2 cam... Also you will love the lokar cable I have the same, the all black one and also have a Lokar pedal. Love it
Old Feb 20, 2012 | 10:24 AM
  #66
04.350z's Avatar
04.350z
Does the lokar pedal mount up correctly? I'd rather not weld a tab on the z pedal ...
And the lokar pedals looked nice. If you could levied a part number that would be awesome
And now I am re thinking not installing the valves springs etc because I did some research on the ls6 springs and they have no business being paired up with a upgraded cam
Old Feb 21, 2012 | 09:19 AM
  #67
04.350z's Avatar
04.350z
Sikky mount kit was ordered this afternoon along with the ps line, master cylinder, and 1 7/8 long tube headers
Old Feb 21, 2012 | 10:46 AM
  #68
Royal_T's Avatar
Royal_T
Congrats
Old Feb 23, 2012 | 04:36 AM
  #69
04.350z's Avatar
04.350z
Sorry for the lack of updates this week.
A few things have come up which won't present a problem but ha to tale a few days off the build.
Me and my fiancé broke things off Sunday night because cars are more important than the wedding which is partial bull **** but reguardless.
Thant being said 1500 bucks was dropped in my lap since I don't have to pay for the wedding any more.
New spark plug wires showed up last night.
And pictures will be posted Sunday of the progress.
This week I am cleaning up the engine removing all grease and grime
Also will be removing the heads from the block and disassembling them.
Parts that have have been ordered as of to day are the following:
Texas speed shop Cam kit * I ordered the tourquer v3 cam*
Texas speed shop deluxe gasket kit
GM performance clutch and flywheel kit
Xmas is coming boys and project ls6 is full speed ahead
Old Feb 23, 2012 | 04:54 AM
  #70
QTB's Avatar
QTB
You sound so so very broken up about it
Old Feb 23, 2012 | 05:46 AM
  #71
str8dum1's Avatar
str8dum1
1500$ for a wedding. were you getting hitched at McDonalds?
Sounds like she saved herself the trouble of a divorce down the road.
Bright side is that you can finish the car much faster now!!
Old Feb 23, 2012 | 07:11 AM
  #72
04.350z's Avatar
04.350z
**** you.
Wedding wasn't for a year and a half that was 2 months of savings...
You sir can eat a dick
Old Feb 23, 2012 | 10:55 AM
  #73
str8dum1's Avatar
str8dum1
Old Feb 23, 2012 | 11:41 AM
  #74
bbs350z's Avatar
bbs350z
04.5, dont mind str8, hes just busting your *****. good news is i broke up w/ my long term gf the other day too, i basically gave her up for lent, or that was my excuse anyways. so with that, we can help eachother out. i got a few ls parts layin around you can pick up now that you got all this extra bank
Old Feb 23, 2012 | 01:58 PM
  #75
04.350z's Avatar
04.350z
What you got and how much?
Old Feb 23, 2012 | 03:38 PM
  #76
Rambo's Avatar
Rambo
What valve springs do you have on your motor currently the Torquer V2 has .600 of lift. If they are stock you may need new springs still.
Old Feb 23, 2012 | 04:46 PM
  #77
2fastnc's Avatar
2fastnc
I love the support for each other on this fourm. This is what its all about.......I just told my wife I will use every bit of alimony she will have to pay if we every break up to fund my car habit!
Old Feb 23, 2012 | 06:28 PM
  #78
04.350z's Avatar
04.350z
The kit comes with upgraded springs according to your build ...
Old Feb 24, 2012 | 08:26 AM
  #79
350z006's Avatar
350z006
Stole this from another thread (sorry Waizz ) but I think its appropo in this thread...
Originally Posted by Waizzz
Old Feb 24, 2012 | 08:41 AM
  #80
bbs350z's Avatar
bbs350z
lots of stock stuff. got 853 heads w/ gm yellow springs, starter, power steering pump and bracket (truck setup), spec clutch disk (3+) bought it used, wear looks good but havent used it, and misc lines etc.
