Having trouble getting drive shaft back in
Old Mar 14, 2012 | 09:05 AM
FineWine's Avatar
FineWine
Default Having trouble getting drive shaft back in
Hey Guys,
I'm trying to wrap up my forever-long turbo build, but I'm having a little bit of trouble getting the driveshaft back into the transmission.
The shaft had a bit of oxidation on it from sitting out near the draft of a door for a long time, but I cleaned it of pretty good with a wire brush. I cleaned the splines before trying to install it as well.
I had a buddy over last night to help force it in. We're able to wiggle it in millimeters at a time, but it's extremely exhausting. We've probably got about 1/3 of an inch left before I can bolt it back up to the pumpkin.
I'm starting to feel like I'm doing something wrong, since I don't remember ever seeing anyone complain about the driveshaft, and a quick search didn't come up with anything either.
Any suggestions on what I could have messed up? Should I try cleaning the splines again?
Old Mar 14, 2012 | 09:43 AM
str8dum1's Avatar
str8dum1
you sure your clutch is aligned properly when you attached the pressure plate?
Old Mar 14, 2012 | 09:47 AM
FineWine's Avatar
FineWine
Yep, clutch alignment tool was in up until I put the transmission back on.
Getting the transmission back in wasn't smooth as butter though, but it didn't feel unnatural.
Old Mar 14, 2012 | 10:35 AM
Cass007's Avatar
Cass007
Lube? I've had mine out several times for months at a time and never had any issues with it sliding back into the trans housing. It may be a PITA, but a pic of said oxidation would be helpful.
Old Mar 14, 2012 | 11:28 AM
FineWine's Avatar
FineWine
Should it slide back in with relative ease?
I've been sitting here replaying it in my head, and I'm wondering if putting it in neutral and dropping the rear mount to get a better angle would help. Maybe the angle is just slightly off and we're working against too much friction. What do you think?
I'll take some pics tonight when I get home.
Old Mar 14, 2012 | 11:29 AM
str8dum1's Avatar
str8dum1
duh i was thinking input shaft.
my DS always slides in very easily may need to media blast the splines
Old Mar 14, 2012 | 11:47 AM
FineWine's Avatar
FineWine
Good idea. I'm gonna pick up a portable media blaster today and give that a try. I could use it on some other parts anyway, so win-win :-)
Old Mar 14, 2012 | 12:20 PM
hellsoldiers08's Avatar
hellsoldiers08
this may sound stupid but you dont have the shaft switched the wrong way?
Old Mar 14, 2012 | 12:53 PM
bbs350z's Avatar
bbs350z
my shaft was always very easy to slide in and out
Old Mar 15, 2012 | 04:01 PM
Sylvan Lake V35's Avatar
Sylvan Lake V35
Mine is fairly thick so usually need some lube but spit will do if no lube is available.
Old Mar 15, 2012 | 07:53 PM
bbs350z's Avatar
bbs350z
jenna jameson says thats the best lube
Old Mar 15, 2012 | 07:54 PM
Cass007's Avatar
Cass007
It should slide in easily and the angle should be a non issue. There is a pivot joint right there.
You cannot do this.
Wondered how many posts this would take to devolve into this... and its 9, did'nt even make it to double digits... so sad.
Old Mar 16, 2012 | 07:07 AM
FineWine's Avatar
FineWine
One more question regardling media blasting. Should I use something softer than plastic bead?
Old Mar 16, 2012 | 09:34 AM
Vivid Racing's Avatar
Vivid Racing
Vivid Racing
No idea on the media blasting, but some high temp grease will make things a bit easier.
Old Mar 16, 2012 | 10:33 PM
str8dum1's Avatar
str8dum1
actually i started it at post 6
Old Mar 18, 2012 | 05:41 PM
Cass007's Avatar
Cass007
I wasn't sure about that one Rich... well played sir, well played.
Old Mar 20, 2012 | 06:40 AM
FineWine's Avatar
FineWine
Just to follow up on this, I cleaned the splines with a brush and lubed it up with some high temp grease and it slid right in.
I'm pretty embarrased at how simple the "solution" was :-/
Old Mar 20, 2012 | 07:40 AM
bbs350z's Avatar
bbs350z
350Z_Al
Oct 29, 2020 07:44 PM
Mattg350z
Oct 2, 2015 06:51 AM
Depravity
Oct 1, 2015 04:49 PM
samansharif
Sep 25, 2015 12:31 PM
