Car Idleing rough
Old Jan 2, 2004 | 10:41 PM
daking350's Avatar
daking350
Default Car Idleing rough
Since I got my car I have had a slight Hesitation at idle..like a slight misfire but no codes...I noticed with the procharger It is more pronounced and fells like it wants to stall sometimes...Car runs very strong otherwise..Just concearns me and hope I dont have any internal damage from N2O or FI....What are some of the things I should look at first in regards to the rough Idle???
Old Jan 2, 2004 | 11:11 PM
GurgenPB's Avatar
GurgenPB
UltimateSleeper
Default Re: Car Idleing rough
Let me help you here - I had the exact same thing and it scared the **** out of me. I thought man! - 27K miles and the car is already in the sewer?! So, I changed the spark plugs - and that's it !!! Runs like it did at 1000 miles!!!
This should be your first try!!! I don't have FI or NOS but I DO run my car REALLY hard. Especially with NOS, you are runnign a veyr good chance of wearing your plugs. The platinums are not designed for extreme temps/loads - only for longevity. So pay $7 a plug and get the NGK iridiums (1 step colder ones - with a "6" in teh model number instead of the "5" - Son't worry - the shop manual specifies these 1 step colder ones)
Gurgen
BTW: got mine at clubplug.net
Old Jan 2, 2004 | 11:30 PM
kzshin's Avatar
kzshin
yeah definately try to replace your plug first
Old Jan 3, 2004 | 05:41 AM
FairladyZ's Avatar
FairladyZ
kaboom!!!!!!
Old Jan 3, 2004 | 07:50 AM
Eagle1's Avatar
Eagle1
Default Rough Idle
DaKing350:
The rough idle from the very beginning, before the mods, is interesting. Maybe it is the plugs, and certainly I would check there first like Gurgen suggested. What, if I might ask, is your idle rpm? Mine is 620 with the procharger, and it just hums happily along even though that is at the lower end of the range. Have you tickled your idle set up a bit to say 650 to see if that helps? Have you any reason to believe you might have something in your fuel line or injectors? Any problem from time to time with moisture in the tank?
Old Jan 3, 2004 | 10:00 AM
daking350's Avatar
daking350
The idle is around625-650..Fuel pressure is steady at 51 psi..Plugs are the NGK 1 step colder plugs gapped to around.039..No vacume leaks..When I put the AC on its much better..I think I have a coil problem or my idle is too low..And its NOT KABOOM...As I ran rich from the begining of getting the procharger and its not running THAT rough..But thank you for the words of encouragement..
Old Jan 3, 2004 | 11:32 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
I'd have to see it to know for sure, but most of the VQ's idle like this...a V series engine is not the smoothest out there by a long shot. if its better with the A/C, just have your dealer use the scane tool to bump it up to 750-800 rpm
Adam
Old Jan 3, 2004 | 01:45 PM
daking350's Avatar
daking350
Adam
Yeah I have heard that they idle rough..Its almost like a little *burp* at idle...It almost sounds like I have a Cam in the car...Weird..but it definitely is not as pronounced without the procharger hooked up..I gues the extra stain on the engine to spin the pulleys makes it worse..
Old Jan 3, 2004 | 02:42 PM
AgentOrange's Avatar
AgentOrange
i used ngk 7s on my 125shot
Old Jan 3, 2004 | 02:50 PM
daking350's Avatar
daking350
and?
Old Jan 3, 2004 | 03:19 PM
AgentOrange
oh hehehehe i ran fine.....i always ran rich.....the nitrous was beautiful nx wet kit and i did a 12.9. We did ngk +7 as well as the company that dyno tuned the car said he tricked out the maf sensor
Old Jan 3, 2004 | 03:58 PM
Enron Exec's Avatar
Enron Exec
My car runs a lil ruffer with the A/C off too, but I thought it was because i broke the car in with the A/C on all summer long. Think I should get he idle set a bit higher?
Old Jan 3, 2004 | 04:01 PM
AgentOrange
i havent noticed a difference in my a/c
Old Jan 4, 2004 | 06:08 AM
daking350's Avatar
daking350
well the ECU automatically raises the idle when the A/C is turned on...
Old Jan 4, 2004 | 07:31 AM
ZedZed's Avatar
ZedZed
Have you tried resetting the ECU? There's instructions on Technosquare's website how to do it.
pslamp32
Feb 8, 2017 09:07 AM
SanmarinoZ
Oct 21, 2015 10:04 AM
05UltraYellow
Sep 24, 2015 05:41 AM
AbrasiveRaysive
Sep 13, 2015 09:52 PM
Darkspy
Sep 7, 2015 09:09 PM
