Which would you do first, Oil cooler or Aftermarket radiator?
Thanks for the link. The one thing I am worried about is the sandwich plate. I hope the HKS charge piping doesn't screw me over. Do you have any pics of the plate installed? You can rotate it 360 right?
It rotates 360 but you have a limited area that it can sit in as there are things in the way/hose considerations.
I also needed a shorter filter stud to delete the OEM oil warmer. It came from an I30 I believe.
The one I am using is from an Infinity.
http://www.infinitipartsusa.com/Infi...521331u00-.htm
In searching the part number I see it is on lots of Nissan products.
well considering the infiniti engines are identical to the nissan ones that would be expected. believe thats the same exact part number i got ordering it from a 07 Z so my guess is w/e infiniti you ordered it for has a vq35HR motor, or wouldnt be suprised if the vq37VHR used the same one as well.
ahh the i30 is a fwd vq, dosnt use a oil cooler but its the same part number as the hr motors for our cars, and what im seeing the fwd vq35de dosnt use a oil warmer either and uses that part but that could be wrong i dont own one *shrug*
hands down oil cooler.
I've ran up to 600hp on my 100% stock cooling system without going over 210* coolant temps on the dyno. Only reason I upgraded my radiator was the deal I got on a mint misimoto radiator. Otherwise I would have left it alone.
Oil cooler on the other hand is almost a must with any turbo system producing power since those turbos will put a considerable amount of heat into that oil.
