cam timing affect compression?
Old Dec 24, 2012 | 01:16 PM
2bad240's Avatar
2bad240
Default cam timing affect compression?
I recently broke a bank 2 intake cam and I replaced both intake cams with revup intake cams. and im having trouble getting the engine timed right.
with the timing set per the fsm the car runs but when I compression test it. bank 1 reads 240psi. and bank 2 reads 90psi. and I can play with the timing of the gears and I can get it to 180bank 1. but bank 2 will drop to 60ish.
I have had the front cover off 7 times now and I cannot find any reason for the compression to be off I have set the timing over and over again. I took the head off to make sure the valves were ok because one of the spark plugs came apart. the top of that cylinder had some dings and the head had some dings. but the valves were fine and the compression of that cylinder reads the same as the one behind it.
Old Dec 24, 2012 | 01:40 PM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
bump
Old Dec 24, 2012 | 02:22 PM
jerryd87's Avatar
jerryd87
you have something crazy going on, need pictures and more info though the one bank seems crazy high if thats a dry compression test and bank 2 is a good bit low. not sure what you mean by playing with the timing of the gears unless your putting it a tooth or two off which could potentially damage the engine.
how did you check the valves and seats? if it dint involve disassembling the head and measuring with precision tools its the wrong answer
Old Dec 24, 2012 | 02:28 PM
Nathan's Avatar
Nathan
When bank 2 cam broke, the valves on at least 2 cylinders would have kissed the pistons. Hence the low compression on bank 2
Old Dec 24, 2012 | 02:32 PM
2bad240's Avatar
2bad240
pictures of what? I have moved them a tooth or two each way. and messed with the timing between the each intake and exhaust cam. and yea dry compression test. cold and with tb closed.
as far as the head goes. my family owns a machine shop and I had my dad check it out.
Old Dec 24, 2012 | 02:35 PM
2bad240's Avatar
2bad240
this is the second time I have broke that cam. and the valves dont touch. it just pops off the last lobe
Old Dec 24, 2012 | 02:53 PM
Nathan's Avatar
Nathan
Unlike most cam-belt motors whose combustion chambers & pistons are designed not to interfere when a cam belt brakes the VQ is not
Old Dec 24, 2012 | 03:01 PM
Nathan's Avatar
Nathan
Just looked again at the picture & can see that the cams are turning & this breakage would only effect that one valve.
If your camshaft timing is correct the compression can only disappear 2 places. Past the pistons or past the valves.
Old Dec 24, 2012 | 03:02 PM
2bad240's Avatar
2bad240
When a camshaft stops, the 6 valves actuated by that camshaft are in various positions from full open to full closed or anything in between. You were just lucky the 1st time that the cam stopped with the valves in a good position.
Look at the photo you posted. If it had been the exhaust cam that had broken, those 2 back exhaust valves are fully open & the piston would certainly hit these as it came up.
I have had the head off and the valves are ok. it just popped that last lobe off and the valve stays shut..
not trying to argue with you about the cam breaking. this thread was to inquire how cam timing affects compression.
jerryd87's Avatar
jerryd87
im willing to put money on bent valves or damaged valve seats. on top of that there has to be something going on causing the cams to break i know people have broken em before but im running stock cams to 7k on bc springs and retainers with 0 issues. on this engine im betting your "messing" with the cam timing by moving the teeth on the timing was causing an issue with the pistons hitting valves at high rpm and thats what is breaking your cams.
Old Dec 24, 2012 | 03:06 PM
jerryd87's Avatar
jerryd87
depends which way you go and how it interacts with the exhuast, by adjusting timing you can raise or lower your dynamic compression(actual compression the engine is seeing.) only way to tell is a **** ton of math or one of the online calculators. however do not adjust cam timing on the chain you will continue to break things because you could be advancing things to the point it hits the pistons. honestly im betting you already did, and since the compression is way off then obviously the valves are not fine.
Old Dec 24, 2012 | 03:14 PM
2bad240's Avatar
2bad240
nah I didnt mess with the timing before when the cam broke. it was all stock then.
Old Dec 24, 2012 | 03:35 PM
Nathan's Avatar
Nathan
At cranking speed the inlet VTC is in the fully retarded position and the inlet valve opens 2 deg ATDC on the revup cam so there is no overlap for compression to escape.
Did you find out what caused the dings on the piston & head?
Old Dec 24, 2012 | 04:33 PM
2bad240's Avatar
2bad240
Obadabot
Jun 18, 2023 11:31 PM
