Brian crower, cosworth or Tomei cams on aps single turbo.
Old Jan 7, 2013 | 08:58 AM
qew's Avatar
qew
Default Brian crower, cosworth or Tomei cams on aps single turbo.
Hello was wondering what cam u guys think I should run with?stage 2or3 crower ,cosworth a bit over a grand or Tomei a bit over 800 ? Saw them on eBay . Here are my specs:APS Single Turbo & Components:
-Garrett twin ball bearing turbocharger
-APS FMIC
-APS High Capacity Engine oil pan
-APS High Volume Twin Vent Blow Off Valve
-APS High Energy Remote Waste gate Pipe & TIAL 38mm WG
-APS Tall-Boy Balanced Distribution Inlet Plenum (custom Polished)
Exhaust:
-APS True Dual 2.5” High Energy Sports Exhaust System
Fuel System:
-CJ Motorsports Stage II Fuel SystemShortblock (components & work):
-CNC machined cylinders
-Wiseco Pistons 8.5:1
-Customs Forged Rods rated to 2200 hp
-ARP Main Studs
-ARP Head Studs
-Rear Main Seal
-Rod Bearings
-Thrust Washers
-Crank Magnafluxed
-Crank Balancing
-Redeck Heads and Block
-Clean Oil Channels
-Rev up Oil Pump
-5 angle valve job on heads
750cc injectors
Ill be having a uprev tune and cam install done by gtm in rancho cal. On 91 and 100 oct. thanks for your input.
Old Jan 7, 2013 | 12:31 PM
revolvedZ's Avatar
revolvedZ
i always liked bc stuff, stage 2 is great for a street car
Old Jan 7, 2013 | 12:45 PM
6mtg's Avatar
6mtg
Modified did a test on 3 the tomei, s1, and nismo cams and they were like 1 hp and 1 foot pound of torquedifferent, for the price I would personally go with the tomei 264 they require no spring or shim since the Lift is less than 11mm, the tomei are 10.8 so your still good for stock valve train but if you want to go with a built head setup ams has a stage 2 head with a good amount of work for 2195 and they give you the option of s1 or s2 cams and they are already shimmed and the springs are upgraded so it all really depends on how much you want to spend
Old Jan 7, 2013 | 12:46 PM
6mtg's Avatar
6mtg
http://www.modified.com/tech/modp-10...m/viewall.html
This is the review they did and the ams head
http://www.amsmotorsports.com/shop/i...s-stage-2.html
Old Jan 7, 2013 | 03:42 PM
qew's Avatar
qew
Thanks fellas!
Old Jan 7, 2013 | 03:52 PM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
Wonder if they ever tested the race cams? I remember reading that one back in the day and really enjoyed it. Think im going to order a subscription lol
Old Jan 7, 2013 | 04:39 PM
eltness350's Avatar
eltness350
The Untouchable
i have the brian crower stage 2 cams/264 and they are a great street/strip cam
Old Jan 7, 2013 | 04:46 PM
jerryd87's Avatar
jerryd87
kelford's, the reverse lobe pattern gets gas out of the engine and into the turbo faster but keeping the intake side smaller improves low end velocity to keep torque up, and have someone else do it dont get **** raped by gtm
Old Jan 7, 2013 | 04:51 PM
2004Black350z
Exhaust Whore
How much is GTM raping em?
Old Jan 7, 2013 | 06:52 PM
qew's Avatar
qew
Thinking of getting jwt cam seems to have a better torque response in the low rpms than the other 2. Gtm is charging about a grand for 10-12 hrs labor on the cam install.I can shop around for someone else to install the cam i guess.this is going into the synth19's old 03 silver 350z I'm the 3rd owner. Got it 2 months ago.
Old Jan 8, 2013 | 02:40 AM
2004Black350z
Exhaust Whore
Well I wouldn't just have any Tom dick or Harry do it. 12 hours of labor which I think is a little high but for 1k I don't think it's bad
Old Jan 8, 2013 | 03:39 AM
6mtg's Avatar
6mtg
I got a quote from z1 for 1800 install plus tuning, I'm going to install mine I just wanted to know how much I was going to save and I was very shocked they quoted me 1800
Old Jan 8, 2013 | 05:07 AM
MR RIZK's Avatar
MR RIZK
i run jwt C2's on a single hks gt3037. find it a bit peaky and if i did it again would go the kelfords
Old Jan 8, 2013 | 01:20 PM
Total D's Avatar
Total D
I am running the Kelford 272's, made 602rwhp on 17psi/93 pumpgas. I am upgrading to a custom set of Kelfords for the new heads I am doing. I have used Kelford on quite of few builds I have done and they have performed very well. If interested in the 272's let me know, as they are coming out in a few weeks, less than 2k miles on them.
J
Old Jan 8, 2013 | 03:02 PM
jerryd87's Avatar
jerryd87
its more a comment about trusting them to do work rather then the price, the amount of horror storys that repeatedly happen with them i wouldnt trust them to swap tires on a bicycle.
Old Jan 8, 2013 | 03:23 PM
qew's Avatar
qew
Total d,pm me a price on those cams.your right jerryd87 that's what I thought from the get go. I called around and gtm has the best price so far and besides that I wanted them to tune it to, 2 birds one stone. I'm actually a 6 year fleet mechanic and didn't want to do it cause I've never messed with overhead cams.But now I'm thinking of buying the shop manual cd and see if I can do it.so far with the stuff I've found online and on my350z it's not looking so difficult. Still up in the air.thanks all for ur opinions.
bcoffee20
Nov 19, 2015 06:39 PM
silverbullet_Z
NA Builds
24
Nov 14, 2015 02:52 AM
tm9293
North East Marketplace
13
Oct 17, 2015 09:14 PM
