My Dyno Numbers
Old May 18, 2013 | 05:05 PM
BadBlu-Z's Avatar
BadBlu-Z
Default My Dyno Numbers
Just Dyno'd my 06 350z at Ptuning on their dyno Dynamics. Here are my results. Seams low to me, What are some of your numbers on a DD Dyno?? Im stock with a CAI and custom TD exhaust. What are your thoughts on these numbers?
Old May 18, 2013 | 05:13 PM
Emski's Avatar
Emski
The CAI is probably messing up your AFR. You need a tune.
Old May 18, 2013 | 05:22 PM
BadBlu-Z's Avatar
BadBlu-Z
AFR is on par for where it needs to be. Gauge bounces between 14.5 and 14.9
Old May 18, 2013 | 05:23 PM
BadBlu-Z's Avatar
BadBlu-Z
I saw an old post of a stock 06 putting down 239 on a DD.
Old May 18, 2013 | 05:56 PM
seymore4's Avatar
seymore4
Professional
At full throttle on the dyno?
Old May 18, 2013 | 06:49 PM
BadBlu-Z's Avatar
BadBlu-Z
Thats what its at while driving.. As far as on the dyno, Im not sure. But the guy said its running pretty efficient, Not much room for improvements. So I don't know. Ill admit to being a noob at this, I have a friend who helps me with the car who knows a lot more and was talking to the auto tech there.
Old May 18, 2013 | 06:51 PM
hellman_x's Avatar
hellman_x
You can't really expect too much from mods with NA.
Old May 18, 2013 | 07:17 PM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
Untuned seems spot on
Old May 18, 2013 | 08:23 PM
seymore4's Avatar
seymore4
Professional
Then you have absolutely no idea and really shouldn't say that its on par where it is supposed to be.
Old May 18, 2013 | 08:55 PM
Bmurray350z's Avatar
Bmurray350z
is it auto??? 217tq??? O.O
Old May 19, 2013 | 08:08 AM
PikachuZ's Avatar
PikachuZ
Dyno Dynamics typically read about 10-15% lower then other dynos FYI. So you could bump up the numbers a little.
Old May 19, 2013 | 08:33 AM
bealljk's Avatar
bealljk
I'm more of a proponent of not needing a tune for a intake and exhaust mods but if youre running a 14-15 afr, then you need a tune…you should be between 12-13 to 1…get a tune and re-dyno on that dyno and see what you come up with.
Old May 19, 2013 | 10:12 AM
BadBlu-Z's Avatar
BadBlu-Z
Its a 6MT. From what one of the guys there said, If I were on a dynojet, The numbers would be closer to 275. Which sounds more reasonable.
Old May 19, 2013 | 11:17 AM
djamps's Avatar
djamps
I was 240whp dynojet no tune bone stock with just a pop charger. Looks pretty strong to me.
Old May 19, 2013 | 01:27 PM
BadBlu-Z's Avatar
BadBlu-Z
Just PM'd you about a question BTW
Old May 21, 2013 | 09:14 AM
QTB's Avatar
QTB
I did my baseline on a DD I think it was in that ball park. I wouldn't get too caught up in the actual numbers of it, they all read a little different.
Old May 21, 2013 | 04:12 PM
jomamahama's Avatar
jomamahama
it's not low, those numbers are in the ballpark
Old May 23, 2013 | 01:17 PM
Alberto's Avatar
Alberto
Cranky FI Owner
People you need to realize DD's can be adjusted with an additional correction. Many shops add in XX% so they read like DJ's. As I believe is the case with this.
A true uncorrected DD is in the 220's. Don't worry about this number just use it as a baseline again for when you upgrade or tune. OP-learn the difference between proper cruising and WOT A/F's. Too much info out there to be so naive and wasting money dynoing your car.
sales@czp
Sep 23, 2019 03:30 PM
