tach wire for converter
Old Jul 25, 2013 | 02:09 PM
blues70t5's Avatar
blues70t5
Default tach wire for converter
I cant find which color wire it is for the wire that goes to the tach in the cluster. anybody know? wireing in dakota digital box.
Old Jul 25, 2013 | 07:43 PM
djamps's Avatar
djamps
There's no tach wire anywhere in the car. It's encoded digitally on the CAN bus.
The closest alternative is an injector lead but your device must be able to multiply the signal.
Old Jul 25, 2013 | 08:47 PM
jerryd87's Avatar
jerryd87
injector wire wouldnt need anything since its 12v(although the ecu triggers ground). would need to know what the converter looks for 12v or 5v, if 5v you wire it to a coil, if 12v need something to bump up the coil voltage. dont add it to a injector because you will fry the injector driver in the ecu, they arnt made to handle the extra resistance.
should have honestly just went with a speed hut tach
edit: looking at the wiring diagram its not going to work because the vq coils arnt triggered off of ground they are triggered of 5v power, ground will be constant because both the ignitor and coil itself are wired to the same ground.
Old Jul 26, 2013 | 04:05 AM
blues70t5's Avatar
blues70t5
there has to be a wire that goes to the gauge its self. something feeds it to tell gauge to move? I don't have a vq any more so I don't need that side of the tach just need wire that comes off the cluster its self
Old Jul 26, 2013 | 06:32 AM
djamps's Avatar
djamps
There isn't one. It's tied into the 2-wire CAN bus. There's two wires that drive almost the entire cluster as well as other stuff like lights and door locks.
Old Jul 26, 2013 | 06:41 AM
blues70t5's Avatar
blues70t5
so there is no way to get my stock tach to work?
Old Jul 26, 2013 | 07:17 AM
undertheradar's Avatar
undertheradar
Try giving Chase Bays a call, i know they make a harness adapter for the DD tach and speedo interface for the 350Z, maybe they will sell it to you separately.
Old Jul 26, 2013 | 09:02 AM
Cass007's Avatar
Cass007
As far as I am aware only 2 shops have managed to get this to work. Diebold Autosport and CiN Motorsports and its myself and CMyTailsBlink that have this done for our swaps. You are getting correct advice though, there is no tach signal wire, it goes through the CANBUS behind the AC controls.
Most people fab the speedhut tach into the stock cluster. I would have done the same had I not had custom LEDs installed already and didn't want to lose them. Making the stock tach work isn't cheap.
Cass007's Avatar
Cass007
It won't work ... hell CB can't even get the harness right.
350Z_Al
Oct 29, 2020 07:44 PM
sales@czp
Sep 23, 2019 03:30 PM
dboyzalter
North East Marketplace
15
May 6, 2018 09:41 AM
Fixxxercask
Interior
Oct 6, 2015 10:17 AM
nanotech
Oct 2, 2015 05:02 AM
