Front hub relative to rear hub...
Old 07-31-2013, 09:10 AM
Phenom
Toasty
Phenom's Avatar
Received 1,382 Likes on 990 Posts
Default Front hub relative to rear hub...
Does anyone know the location of the front hubs with respect to the rear hubs? In other words, are the front and rear hubs in line with each other when looking directly from the front or rear of the car? And if not, what is the measurement of the offset between the them? Specifically I'm interested in the surface of the hub in contact with the wheel.
This is pretty much just out if curiosity as its something I was never sure of with our cars.
Old 07-31-2013, 03:16 PM
Nathan
Nathan's Avatar
2003 Z33
Front Track 1535 mm
Rear Track 1545 mm
Old 07-31-2013, 03:18 PM
terrasmak's Avatar
Received 2,291 Likes on 1,651 Posts
Originally Posted by Nathan
2003 Z33
Front Track 1535 mm
Rear Track 1545 mm
Is that track or hub to hub?
Old 07-31-2013, 05:37 PM
POS VETT
POS VETT's Avatar
Add the difference in wheel offsets to those numbers.
Old 07-31-2013, 06:02 PM
terrasmak's Avatar
From what wheel, the 17's , 18's or track 18's? All will give you a different numbers, also its a bit more complex than that doing it your way, you also have to account for wheel width coming off the track measurement to get hub to hub.
Old 08-04-2013, 09:43 AM
T_K
T_K's Avatar
Track width should be measured from the tires centerlines, wheel widths wouldn't matter.
The rears had +30 and +33 wheels though, so it depends on which model the track width is advertised off.
Old 08-04-2013, 10:31 AM
terrasmak's Avatar
Track with would be outer edge of tire to outer edge of tire (maybe wheel ) with track width and if you know what wheel and offset you can get the hub to hub measurement
Old 08-11-2013, 11:51 AM
T_K
T_K's Avatar
Track width is standardized as centerline to centerline, it's not measured the way you're describing.
Obadabot
06-18-2023 11:31 PM
08-06-2021 06:19 AM
Quick Reply: Front hub relative to rear hub...
