SS clutch line troubleshooting
Old Sep 9, 2013 | 08:54 AM
kingdom's Avatar
kingdom
Default SS clutch line troubleshooting
Hello all. I am trying to install a SS clutch line in my '05 350z.
As many people, I am having trouble removing the hardline nut.
I believe I can get the nut off but I fear by the time I do it will be mangled and unusable for re-install.
My plan is to cut off the mangled piece and replace it.
Therefore I need help figuring out the size, type or a link to the correct: clutch hardline nut, flare nut or pipe fitting.
Should look something like this, i think:
I intend on using a flaring kit like this one to install the new fitting.
Any insight would be helpful thank you!
Old Sep 10, 2013 | 05:00 PM
04DaytonaZee's Avatar
04DaytonaZee
I used a pair of small locking pliers to loosen mine, and then still had enough wall on the outside of the nut to tighten with the proper flare wrench. Might as well try it before you cut it off.
Old Sep 10, 2013 | 09:22 PM
PercisionDriver's Avatar
PercisionDriver
Bro, soak it in penetrating oil and use a flare nut wrench. I thought I was screwed too; until I just kept it routinely soaking it for a few days, and just went at it with a flare nut wrench. Otherwise, as mentioned, we used a vice grip on a buddies, and was still able to get it back on a new SS line.
Old Sep 11, 2013 | 04:41 AM
kingdom's Avatar
kingdom
I have a flexible flare nut wrench but it just spins on the nut (even though it doesn't look very rounded to me).
It is a 10mm correct?
Old Sep 16, 2013 | 11:30 AM
JasonZ-YA's Avatar
JasonZ-YA
i also used a flarenut wrench, a swivel one i found at autozone i think:
from my thread here:
https://my350z.com/forum/engine-driv...voir-swap.html
if you can't get it, just buy another hardline, nab one from the junk yard...?? if not try flaring, but ensure you have a good flare and seal when its all done.
-J
Old Sep 16, 2013 | 11:41 AM
terrasmak's Avatar
Vice grips on the mangled nut, then use vice grip to reinstall
Old Sep 17, 2013 | 05:14 AM
kingdom's Avatar
kingdom
-J
Thats the weird thing, I used that exact wrench from the start. The nut isnt even all the way rounded, yet the wrench spins on it. (yes i am using the 10mm side)
Thanks for the advice.
Thats the plan.
EnjukuRacing
Sep 30, 2015 06:55 AM
