Aftermarket Slave Cylinder for DE???
Old Mar 22, 2014 | 07:17 PM
350zlaboy's Avatar
350zlaboy
Default Aftermarket Slave Cylinder for DE???
I have a 2003 350z DE and I recently found out my oem clutch slave cylinder (csc) is bad and thought buying an aftermarket one would be better choice than oem since it seems to be a common failure with oem csc. I tried to do some research but only found information about the HR csc. I realize that zspeed makes an HD heavy duty concentric master and slave cylinder but its only available for 2007 Z's and up. My question is what can I do, other than buying another oem csc that might fail on me again. Is there a company that provides a good aftermarket clutch slave cylinder for 03-06 350z?
Old Mar 22, 2014 | 07:50 PM
dkmura's Avatar
dkmura
General & DIY Moderator
There's been little demand for an aftermarket VQ35DE slave. The HR uses a concentric slave cylinder (CSC), which is a different design. The DE uses an external slave, which is better isulated from heat and vibration, and the OEM unit (or aftermarket equvalent) is much more reliable.
Old Mar 23, 2014 | 12:58 AM
terrasmak's Avatar
Never knew there was any demand for an aftermarket DE slave.
Old Mar 23, 2014 | 05:32 AM
dkmura's Avatar
dkmura
You're looking at it, right here...
Old Mar 23, 2014 | 06:23 AM
tphss's Avatar
tphss
Here, Dorman slave cyl:
Amazon.com: Dorman CS650096 Clutch Slave Cylinder: Automotive Amazon.com: Dorman CS650096 Clutch Slave Cylinder: Automotive
Old Mar 23, 2014 | 06:38 AM
terrasmak's Avatar
157k on my Original slave and master, I should probably rebuild them.
07ZEKE
Aug 23, 2021 09:15 PM
sherm
Apr 11, 2020 05:21 PM
350z82
Oct 1, 2015 06:25 PM
SharX59
Sep 27, 2015 09:23 AM
