05 350Z N/A Rebuild
Old Mar 24, 2014 | 09:31 AM
Bill350z's Avatar
Bill350z
Default 05 350Z N/A Rebuild
I just want to start off that I absolutely love my Z. Unfortunately Ive grown tired of just cruising around with no significant power. My Z is pretty much bone stock, I want to get 320rwhp while still being N/A. I understand this might be an expense but im sure its cheaper than FI. If anyone could help me out on a list of parts that I might be able to accomplish my goals and provide pricing I would greatly appreciate it, Thank You.
Old Mar 24, 2014 | 09:37 AM
Syner's Avatar
Syner
Personally, I haven't heard of a n/a Z making 320WHP.
Old Mar 24, 2014 | 10:08 AM
Suwaidi's Avatar
Suwaidi
N/A is in no way cheaper than FI, in fact it'll be a money pit well before you reach your power goals. In general from what I've seen with an exhaust, intake, test pipes and a tune (on a Dynojet):
HR - 295-305
DE - 265-275
If it's power you seek, it's FI you shall invest in.
Old Mar 24, 2014 | 10:38 AM
iideadeyeii's Avatar
iideadeyeii
See sig
Old Mar 24, 2014 | 10:42 AM
npr350z's Avatar
npr350z
Originally Posted by iideadeyeii
See sig
I see what you did there...
Old Mar 24, 2014 | 11:04 AM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
Do some research on the na builds sub forum. Then come back and make a new thread
Old Mar 25, 2014 | 01:57 AM
Bill350z's Avatar
Bill350z
Oh... well that changes everything haha I just figured N/a was cheaper due to the fact that these turbo kits that ive found (which there might be others) but they are running like 9 Grand. Also I understand that the VQ is a high compression motor so I just assumed N/A was the way to go. Im honestly just looking for a way to have my goal and not destroy the bank.
Old Mar 25, 2014 | 02:20 AM
2004Black350z
Exhaust Whore
Buy a civic then
Old Mar 25, 2014 | 02:23 AM
padilla03z's Avatar
padilla03z
Look into nitrous then. There was one na build that was like 350 whp or more but it was a custom shop build wit itb's
Old Mar 25, 2014 | 03:27 AM
RENFRO's Avatar
RENFRO
Best way to reach that power number is to keep an eye out for a used vortech or pro-charger kit in the marketplace. I've pretty much done every bolt on you can do and sitting right at 275rwhp/265rwtq on my 03 DE. To reach the number you want you're talking about a built block, heads with port work, cams, some type of custom intake manifold (i.e. ITB's would be best), with ITBs you'd also need standalone engine management, and plenty of supporting mods to keep it nice and cool.
I've got some buddies going down that route and it's been full of letdowns attempting to reach just 300rwhp. However, don't discount the effects of some nice boltons and re-tune. My car feels much stronger than when it was stock. I'd stay just start with some simple things: test pipes, exhaust, intake...then once you're done get a good dyno tune.
Old Mar 25, 2014 | 06:10 AM
Bill350z's Avatar
Bill350z
Well I appreciate everyone's input and ill try to keep in touch on what exactly im going to be doing.
Old Mar 25, 2014 | 07:43 AM
The_Assassin's Avatar
The_Assassin
if you had an hr then full bolt ons and cams should put you close to those numbers. Not so sure if you will reach that number with an 05 staying NA
Old Mar 25, 2014 | 08:31 AM
Bill350z's Avatar
Bill350z
Ive decided on FI but now im completely lost on what are good brands that are not crazy expensive because im not looking to push crazy amounts of boost.
Old Mar 25, 2014 | 08:37 AM
npr350z's Avatar
npr350z
Start off with your power goals.
300-375 I'd say stillen
400-550ish vortech
Anything past 500 really a turbo / twin turbo
But you could always just get a single turbo for 300-600
So you got choices. I'm sure someone will chime in otherwise or point you in a different direction.
But decide on your goals, take your time, and do it right.
Old Mar 25, 2014 | 09:53 AM
KA24DE's Avatar
KA24DE
Spend your money on the parts that make power: Longtubes, Cams and intake manifold porting.
Optimize those three and you can make 300whp+ - Sasha did it.
Old Mar 25, 2014 | 05:44 PM
KA24DE's Avatar
KA24DE
http://www.onpointdyno.com/?p=1110
Old Mar 25, 2014 | 05:51 PM
npr350z's Avatar
npr350z
Mmmm very good read.
Old Mar 25, 2014 | 06:04 PM
MI 35th's Avatar
MI 35th
OGPremierMafia
400 hp na is LS swap!
Old Mar 25, 2014 | 06:48 PM
RENFRO's Avatar
RENFRO
Lets not forget Sasha did that on their RACE engine. It was fully built and the cams they used were 300s. Good luck going any higher than 272s on a stock engine. Throwing longtubes, cams, and porting your intake manifold more than likely won't get you 300rwhp on a stock block.
Edit: I noticed they didn't build the block until later...still, I'd find it surprising to hit that number with just the mods listed above. Who knows? Best of luck OP
liqalu04
Jan 2, 2022 12:58 PM
issyz
Jul 2, 2017 03:04 PM
wanderingstuden
Jan 28, 2016 07:03 PM
Justin100
Nov 29, 2015 03:58 PM
codek
Sep 28, 2015 03:03 AM
