Revup motor in a non revup car
Old Apr 10, 2015 | 05:34 PM
thejushinator's Avatar
thejushinator
Default Revup motor in a non revup car
So recently the engine in my 2004z 350z 6spd let go. I found a great deal on a engine from a 2006. I know it is a revup engine and has a few more cam sensors in the front of the engine. Can those sensors just be left unplugged? If not, can I just swap the heads from my 2004 on the 2006?
Old Apr 10, 2015 | 11:17 PM
terrasmak's Avatar
Swap timing covers , and run a plug in the extra port on the backside of the head
Old Apr 11, 2015 | 04:25 AM
thejushinator
Thanks.
Old Apr 11, 2015 | 05:13 AM
2bad240's Avatar
2bad240
As he said just switch timing covers. Make sure you switch the back piece to the timing cover also. I didn't and there is 1 bolt that don't line up.
Old Apr 11, 2015 | 11:16 AM
thejushinator
I'm assuming once I get the timing cover off I will know what you are talking about but where is the back piece you are talking about?
Old Apr 11, 2015 | 11:47 AM
terrasmak's Avatar
2 piece timing cover, change front and rear. I did it on my spare motor last week. Then it took me 5 minutes to sell off the rev up timing cover I had no need for
Old Apr 12, 2015 | 07:33 AM
thejushinator
I just found out it is from a g35. Does that make a difference?
Old Apr 12, 2015 | 11:19 AM
Pengu's Avatar
Pengu
Are you sure it's a Rev up then? I believe only manual G35's had the Rev up motor.
Old Apr 12, 2015 | 11:54 AM
thejushinator
It is out of a 6spd g35.
Old Apr 17, 2015 | 05:17 PM
thejushinator
Ok,
so I have the revup motor in my car. I am almost positive what to do now but I want to double check. What I have circled in blue I should take off the revup motor. I should then replace that with the bolt that is in my old motor. I will then take the timing cover completely off the revup motor and put the timing cover from my old motor on it. Also there are 4 cam sensors on the back of the heads. What 2 sensors should I hook my wiring harness to?
Old Apr 20, 2015 | 07:09 AM
thejushinator
Old Apr 20, 2015 | 09:34 AM
Xonatron's Avatar
Xonatron
What happened to your original engine? Anything we can learn from?
Old Apr 20, 2015 | 01:00 PM
AARONHL's Avatar
AARONHL
Yea I'd like to know too because I have a 04 g35 6mt sedan and it burns just as much oil as the revups
Old Apr 20, 2015 | 10:01 PM
terrasmak's Avatar
I wish I had more parts available in front of me to look at. I know rev up cams have been used in many non rev builds, so I know it's possible. The cans from my spare motor were sold to someone doing this. I haven't done this myself, my rev up to de build is going to have aftermarket Non rev cams.
Swapping you your Non rev cams is easiest , but you have the rev up cams to run.
Old Apr 22, 2015 | 05:47 PM
2bad240's Avatar
2bad240
You can use the intake cams with either cam gear. And you can even use the exhaust cams with the de gear but you need a different bolt as the threads are deeper inside the cam and the stock bolt isn't long enough. I think I was told a vq30 bolt would work
Old May 13, 2015 | 05:31 PM
thejushinator
I purchased the car about a week before the engine starting knocking. It had low oil pressure when purchased.
I was able to locate the bolts I needed at a parts store.
Engine is running like a champ.
Old Jun 2, 2015 | 05:02 AM
G87z's Avatar
G87z
So, with the parts swapped from the DE motor. Is it still A rev up?
gc350z03
Oct 28, 2016 05:00 PM
Juztin
Nov 22, 2015 07:03 AM
Vigman
Nov 17, 2015 04:34 AM
nissan1310
Oct 12, 2015 08:54 AM
Bigsyke
Sep 11, 2015 06:19 PM
