Transmission Noise on Low RPM
Old Dec 17, 2015 | 03:25 AM
Lord Shogun's Avatar
Lord Shogun
Default Transmission Noise on Low RPM
Good morning,
I recently replaced a lot of parts in my transmission, these exact parts:
http://www.zspeedperformance.com/ZSP...SPNSK1PACK.htm
http://www.zspeedperformance.com/ZSp...P3003-DEHR.htm
Performance wise... works great, it still tight, I'm still in the 500 mile break-in period, but so far its excellent.
BUT... there is a noise... sounds are hard to explain. So...
First... for the 350Z MANUAL transmission.... that rattle sound it makes when you forget to press the clutch in when you turn off the car... that sound is the closest i can describe.
When I am at very low RPMS, under 1,000, it makes that rattle noise, it doesn't do anything else, no shakes or vibrations or jerks. It does it in first gear when I do a shallow engage and 2nd gear if its lower than 1k RPM after my shift.
Is this sound anything serious?
Old Dec 17, 2015 | 03:42 AM
travlee's Avatar
travlee
Master
does it do it in neutral just idling and then go away when you push in clutch?
Old Dec 17, 2015 | 03:55 AM
Lord Shogun
No.
It only makes the sound when i am actively pushing the gas pedal at lower than 1,000-1,100 RPMs, it goes away once I'm over that.
Old Dec 17, 2015 | 03:57 AM
travlee's Avatar
travlee
Master
do you have a DE or HR?
Old Dec 17, 2015 | 04:42 AM
Lord Shogun
HR
With heavy duty all metal master and slave cylinders with new heavy duty hydraulic line.
Old Dec 17, 2015 | 04:46 AM
travlee's Avatar
travlee
Master
did you do the work or did a shop? if you did it, did you put loctite on the bolts holding the flywheel in?
Old Dec 17, 2015 | 04:47 AM
Lord Shogun
I took it to a shop that only does transmission work, and on top of that, I took it to them because they have a few 350Z's that they've sponsored and upgraded themselves.
Old Dec 20, 2015 | 07:58 AM
guitman32's Avatar
guitman32
Completely normal...
It does this stock, but converting to a single mass will amplify the transmission rattle that was already there.
Old Dec 29, 2015 | 07:57 AM
ZSpeedPerformance's Avatar
ZSpeedPerformance
Vendor - Former Vendor
This is correct, Because the Dual Mass OEM flywheel is now replaced with a single mass you may get some light noise under accelerating condition in the low RPM range. This is completely normal.
superpreditor
Feb 2, 2022 02:35 PM
dlkaye04Z
Dec 18, 2015 04:24 PM
burglapfd
Dec 13, 2015 02:47 PM
blackludebosh
Dec 9, 2015 11:52 PM
nvmynismoz
Nov 29, 2015 07:09 AM
