Oil in exhaust
Old Feb 28, 2016 | 02:14 AM
03autoz's Avatar
03autoz
Default Oil in exhaust
Yesterday I did an oil change on my 03 z, I decided to put synthetic oil in, my current mileage is just under 100,000. When I got on it I noticed white smoke come from the back for just a second. When I got to my destination I noticed oil all over the undercarriage on the drivers side. The engine is no longer leaking from anywhere that I can see but when I start the engine up Im still getting oil spatter from the exhaust. Any ideas on what might have happened?
Old Feb 28, 2016 | 05:52 AM
dkmura's Avatar
dkmura
General & DIY Moderator
You're burning oil- either head or ring problems. Have you ever done a leak down or compression test? The oil on the undercarriage is likely from a separate source. Time to more closely monitor oil consumption and evaluate overall condition of your VQ.
Old Feb 29, 2016 | 10:46 AM
cincysilvias14's Avatar
cincysilvias14
how is the seal on the oil pan? my 04's shot and needs replaced. im leaking about a qt onto the aluminum skid plate every fill up.
Old Mar 5, 2016 | 12:27 PM
Spike100's Avatar
Spike100
White smoke might indicate coolant leaking into the engine via the head gasket.
If so… Best case you have a faulty/leaking head gasket; worst case you have a warped head (and consequent leaking head gasket).
kennyy
Apr 23, 2018 06:14 PM
Nolan23
Mar 1, 2016 03:20 PM
Freakville03
Feb 25, 2016 03:33 AM
BIGPOPPAPUMP
Feb 24, 2016 07:29 AM
vagel72
Feb 23, 2016 09:06 PM
